Question about Maytag Neptune MAH5500B Front Load Washer
My washer is making a buzzing sound and does not start making sound from where latch is will not release the door its staying locked . the code its showing is FL and DO.
  • 82 Answers
If you open the dispenser door on top of the washer, and feel around the front you should find a little green ripcord. pull on the cord until the door releases. most likely the wax motor in your door latch is fried.
Posted on Jul 17, 2009
How do I get the Whirlpool washer door to close all the way? I think the door lock is jammed
The lock/latch on your door is electromechanical, incorporating a electrical safety catch. See if a reboot (unplug for 10 minutes, then plug it back in.) does anything for you. It could be a latch, wiring, motherboard, door closed safety circuit or something in the pause circuit.
Jul 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Door lock sensor on affinity washer
It sounds like the entire door latch assembly needs to be replaced. The sensor inside is no longer communicating correctly with the main control board.
Aug 29, 2012 | Frigidaire ATF6000ES Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer. Door will not unlock get error code "do" or FL. Door lock light is not on but door is locked and wont unlock. You csn hear a buzz as the lock energizes but does not unlock. Allready...
Sturdy little door, isn't it? Make sure you don't have extra water in the machine, as this will cause the door to not unlock. With that done,unplug your washer. If you can get the top of the machine off and reach down the front of the washer, you should see the latch mechanism. Push this down. Door should unlock. Now. Buy a new latch assemby.
Mar 16, 2010 | Maytag MAH8700A Front Load Washer
Makes a loud buzzing noise when attempting to start cycle
The lock solenoid on the door latch assembly may be hanging up or just noisey. If washer starts and runs then all is ok. If washer wont start, just buzzes, then door latch assembly may have to be changed.
Feb 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Ge Adora front load washer not working
I don't know how you could have got it into diagnostics mode by accident - - but here's how it goes . Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Jul 30, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
511 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
