Question about Goodman CLQ36AR49 Air Conditioner
The circuit breaker trips every time I turn the thermostat to on. The system hasn't been on in a few months, and when I turned it on today, it wasn't pushing cold air out. I saw that the circuit breaker trips for the "HVAC" in my panel as soon as I turn the unit to on. This is A Goodman Model A 36-15
  • 585 Answers
You need to start with a basic inspection in the outside unit. For the breaker to trip immediately like that indicates a dead short. With the breaker OFF look at the internal wiring between the contactor relay and the compressor. You are looking for signs that the insulation may have been chewed by a rodent, or a wire is off of a terminal and in contact where it shouldn't be. If the wiring looks good, terminals pass tug test etc. you may have a shorted capacitor. Make sure to check the wiring for the fan too. You can disconnect the com lead for the compressor and fan one at a time to isolate the defective component if needed. Work safe! turn the breaker on for the test, and off again before you put your hand or tools back in.
Posted on Jul 17, 2009
My tub keeps tripping the breaker, but after it kools down I can trip the breaker back on, but it hits 100 and trips the breaker again, could this be the heater?
What Trips?
  • the "Actual" electrical circuit breaker?
    • Is it GFCI Style?
or...
  • Is the high limit switch tripping?,
    • which isn't actually a breaker.
  • A circuit breaker is a breaker that toggles as a switch, and to reset it you have to switch the toggle switch ALL the way to Off position to reset, then switch it to on.
    • Same thing if it were a GFCI style, it just has a 'Test' button on the body of the breaker, that button is usually a white rectangular button.
  • Some systems have a GFCI breaker that looks totally differnent from above... It's located on the control system itself, very similar to what you may have in your bathroom or kitchen of your home! It will have a 'Test' button AND a 'Reset' button.
A High Limit Switch, acts like a breaker, as it will trip when it senses a temperature greater that it is set for as a safe temperature. Once that temp is breached, it will trip.
So... Which one is tripping for you? What are you resetting to turn it back on?
if circuit breaker, it has nothing to do with the 100 degree temp you mentioned. If that trips,= electrical problem, either a short or overheated electrical appliance (internal wires) aging motor pulling too much current, loose electrical connections generate heat, etc.
if High Limit, then possible overheat of water? Many times, failed thermostat. I already know what you're thinking... But I never saw water get Hot! But... Many times that IS just the case , it's just you never noticed the water hot, and it has been cooling down when you saw it.
Apr 14, 2015 | Pool & Spa
Refrig circuit breaker
It needs to be determined wether it's a dead short or the compressor is bad. A dead short is when the hot (colored) wire is in contact with the neutral (white) wire in a 120 V system.
I would get to the compressor connection box and disconnect the power from the compressor and turn the circuit breaker on. If it trips, it's a wiring problem. If it doesn't trip, the compressor is shorted internally.
As an alternate test to disconnect the compressor, you can turn the thermostat to off and reset the breaker, if it trips, then it's a wiring problem, if it doesn't trip and as soon as you turn the thermostat to on, then you must go to disconnecting the compressor and check it again with the compressor disconnected.
Other tests, an electrical meter is required.
Apr 12, 2014 | Dometic Refrigerators
When plugged in & turned on... It doesn't do anything... No lights at all.
Check the outlet that it's plugged into, to make sure that the outlet is still active and a circuit breaker in your home's breaker panel hasn't been tripped. If nothing else, plug the unit into another outlet, that's on a different circuit.
Apr 28, 2011 | Air-O-Swiss AOS 7135 Humidifier
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
Jan 07, 2011 | Water Heaters
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
Thermostat
Is this a new installation? If so the elements may be pulling more load than the circuit can handle. That or you have a weak breaker. See what size the breaker is I.E. 20, 30, whatever, and see how may watts the heater is making. Divide that into volts (ohms law) and that should give you the amp draw. If its higher than the number on the breaker, then its overloading. If its lower but the breaker still trips, then change it.
Mar 02, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Goodman CLQ36AR49 Air Conditioner Logo
437 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
