Question about Refrigerators
Whirlpool refrigerator, ice maker stopped working. Line is not crimped or frozen. Thanks for any help! Model ER2CHMXPL00
  • Refrigerators Master
  • 1,606 Answers
Is there ice frozen in the icemaker ? If not , pour about 1/2 cup of water into it . If it dumps , then the problem is the water valve . If not , then the icemaker is bad .
Posted on Jul 17, 2009
The ice maker in my Whirlpool Gold (Model GI6FDRXXY07) stopped making ice. I can get water from the door and can hear the ice maker cycling. It is calling for water but the flow valve is not opening.
The same valve that the water comes from except there are two halves to the valve. The valve you need is a=> Whirlpool Refrigerator Water Inlet Valve WPW10312696 The problem is with these models the ice maker tends to function a little causing you to believe it is OK when they are worn out. I can point you to a manual to see if the water valve works by going to page 18 HERE and use a jumper wire between test point L and the letter V. Make sure the wire is insulated so you don't get shocked. Otherwise the ice maker may need to be changed and it is less expensive than the water control valve Ice Maker=> HERE
APPLIANCE911
E-Mail Contact Me Here
Aug 29, 2016 | Whirlpool Refrigerators
Icemaker makes lil ice cubes now could this mean the line is clogged?
Would not expect you to ask this question but yes you are right cajunboudoin, an obstructed water line by either a defective water control valve, water filter beyond its useful life or a crimped water supply line will cause the ice cubes to be small during drop of ice cubes into ice bin. Fact is with Whirlpool the water valve is set to remain open filling ice maker for around 7 seconds. If water is moving slow filling the time will be to slow for the flow, If anyone has a good question you do but I would always want everyone to provide their model number, Click Here=> Whirlpool Ice Maker Troubleshooting Thanks Sea Breeze
May 06, 2012 | Maytag Refrigerators
No water going to ice maker
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool GC5SHEXNS Side by Side...
Exterior water function stopped working. This is simultaneous with me removing the ice holder to defrost, then replacing. Ice maker functions and all else seems normal.  It seems like water and ice...
ck the fresh food tempt it may be too cold . and has frozen water line . adjust to a warmer tempt and it should start working .. mm ps in 24 hr or so ..
Dec 23, 2009 | Refrigerators
Model ER2CHMXPL00. Some of the water freeze on the
This is most likely caused because the defrost condensate drain below the evaporator is frozen over or blocked further down the drain line. You will need to remove the rear cover unplug the refrigerator and defrost the drain pan with a hair dryer until you ar able to pour water with a mixture of clorox and allow to flow to the pan below your refrigerator. I have more information on the link below. Click on the link and read the complete page and use the parts that refer to your leaking problem. If you need further assistance please feel free to let me know. Thanks, Sea breeze
Click Link Below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 25, 2009 | Whirlpool Refrigerators
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water not flowing to Ice Maker
take your icemaker back out and take a hair dryer and blow it up the tube probably 10 to 15 mins
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool icemaker not working
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees.
Jun 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
