Top part of agitator does not move with bottom of agitaor
Top part of agitator does not move with bottom of agitator
    President:
  • 1,136 Answers
Hi, Remove the cap on the agitator and locate the 7/16" bolt. Remove the bolt and the agitator will lift out. Seperate the agitator and replace the dog kit inside the upper half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 17, 2009
GE PROFILE wprb8050. agitator will not spin. I removed and found the coupler is moving left to right, just will not turn agitaor. it appears to be loose? any suggest?
If you can easily spin that agaitor coupler free by hand..its stripped and needs to be replaced. The part number for it is WH49X10042 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE
Aug 30, 2011 | GE WPRB8050D Top Load Washer
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Aggitator does not appear to be working properly (sluggish). Not much movement. What do I need to do? Do I need to replace a part?
You probably have a two piece agitator and most likely the upper agitaor is not ratcheting like it should.To test-- take your hand and put it on top of the agitator (UNIT UNPLUGGED). See if you can rotate it 180 degrees in either direction.
If you can , then you need new agitator dogs
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Jun 12, 2009 | Kenmore 22942 Top Load Washer
The slow weak function of the augar
the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 15, 2009 | Whirlpool LSR6332K Top Load Washer
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
Kenmore series 80 model 1102983120 older top agitator gone
if just the dogs are gone you can replace them wim any agitaor dog kit. I usually use whatever kit was cheaper when i order abd put just the dogs on. never had a problem yet.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator
agitaor repair kit for Roper RAS8445KQ model
Sep 04, 2008 | Roper RAS8445KQ Top Load Washer
Trans will not disengage
either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
Mar 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I remove Kitchenaid Washing machine agitator?
with the palm orhte heel of yuor hand smack the top of agitaor, hte fabric softener cup will release.it doenst seperate to clen any furthetr though reccommnd soaking in hot water to clean out. reach down and pull up the opaque cover from the center of agitatr and there you will fond a 7/16 bolt holding the agitator to the tranny shaft. remove bolt adn PULL up
Mar 10, 2008 | KitchenAid KAWS750L Top Load Washer
Agitator
the agitator is supposed to do that in wash dont worry
Jan 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
