Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door opens after closing
When the door reaches fully closed position it automatically begins to open again. The door won't stay closed. I've adjusted the limit sensor in both directions and it still doesn't stay closed.
    President:
  • 3,197 Answers
If the main light flashes 10 times when the door reverses it is a door sensor problem but if the door is hitting the floor and reversing and the main light is not flashing then the door is closing too far and the safety thinks it has hit something. On the side of the motor unit you will find 2 controls. One of these is the 'down limit'. Turn this in the opposite direction of the arrow printed on the cover until the door closes but does not reverse.
Posted on Jul 17, 2009
The down adjustment broke off
Check the micro switch that will be activated when the door reaches the closed position. It might need to be readjusted as it is supposed to be activated just as the door reaches the fully closed position to stop the further movement of the door. If it does not get activated at that point the door will try to open further but sence an "obstruction" and start opening again as a buildt in safety measure for protection against possible injury or damage to property.
Jul 23, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Garage opener try to close door when door at close position
There are upper and lower limit settings, it sounds like you have the lower limit set to low. Adjust it so it stops the door as it contacts the floor and see if this solves the problem. It is possible these limit controls are damaged and will not stay set. If that is the case it may be best to replace the opener if you cannot find a replacement.
Apr 06, 2014 | liftmaster Chamberlain Garage Door Opener...
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Oven door will not fully close allowing heat to escape and light stays on
Is the door locked? if it is it won't close all the way if it was in the locked position before it was closed. like if it was programmed for "self clean" without the door being closed, the lock would be engaged still.
Jun 09, 2012 | Electrolux EW30ES65GS 30" Slide-in...
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
I have a 1/2hp master mechanic door opener. when I close the door it goes the full travel down and then opens back up. i checked the eyes and everything was lined up. do you have any suggestions?
Look at the setting for "fully closed". it sounds like yours is set for slightly than the actual opening....So, the door reaches that location, and it thinks it hit an obstruction, which causes the door to open....While you are there, reset the sensitivity settings.
What I would do is back off the closed position setting so that the door stops an inch or two off of the ground, then adjust until the door is in the correct closed position...
You are correct on the "eyes" (infrared sensors) being lined up, if they were not, the door would not close at all.
Mar 15, 2011 | Vacuums
2008 Dodge Grand Caravan side door does not automatically close.
sounds like the door sensor switch is malfunctioning and when almost closed it reacts like it is blocked (such and kid in way) and opens for safety. try flushing trach with hose and try again, if not u need a good repair manual such as chiltons($25 most parts stores ) or see mechanic
Jul 07, 2009 | 2008 Dodge Grand Caravan
The door reverses back to open position instead of closing
SOUNDS LIKE A SENSITIVITY ISSUE UNHOOK THE DOOR AND TRY IT MANUALLY TO BE SURE IT DOESN'T BIND OR IS TOO HARD TO OPEN OR CLOSE.
IF ALL IS WELL CHECK THE SENSITIVITY SETTINGS ON THE BACK OR SIDE OF THE OPENER.
YOU WANT THIS SET AS LOW AS POSSIBLE AND STILL OPERATE THE DOOR WITHOUT REVERSING.
NOTE: THE FULL RANGE OF ADJUSTMENT IS ONLY ABOUT 3/4 TURN SO MAKE A VERY SLIGHT ADJUSTMENT AND THEN TRY IT AGAIN.
HOPE THIS HELPS
Feb 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
350 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
