Question about Hayward Navigator Pool Cleaner
Gets stuck on walls
Seems to go to the side of pool and gets stuck jammint the side wall
    Problem Solver:
  • 12 Answers
Turn down the suction if thats not the problem under the left rear pod on the body housing youl see a little straight slot for a screw driver theres 3 settings it actually shows images like a ladder turn the screw down to the first step that should solve your problem
Posted on Oct 08, 2009
If dolphin turns on its side against wall , will not flip back upright. Continues on its side and won't move
I am unsure of your question. Are you referring to an actual Dolphin or some sort of Toy?
May 16, 2017 | Dolphin Pool & Spa
My Kreepy has a Starfish seal on it. It is being used in a pebble tec pool. I bought it new less than a year ago. Here are my problems...The Kreepy is getting stuck by my stairs (they are more like...
If the cleaner is getting stuck on objects (steps, ladder, corners, benches, etc), you need to remove the dive float restrictor and install a wall climb adjuster. It is part number K12065. Anyone that sells Pentair products should have one. This will keep your pool cleaner from becoming stuck. It might also help with the seal problem, but that is most likely something caught in the flapper. Check to be sure that the pool cleaners getting proper flow and that the flapper is clear of debris.
Jul 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
When I turn on the pool, the pacer works for about 5 minutes then just gets stuck on the wall. If I turn off the pool and reset, it starts again then stops. How can I decrease the suction or adjust the...
You need to use the Pool Pulse feature to control the flow of water through the cleaner. Here is a brief overview, but if you need more details, consult page 6 of the users manual for this pool cleaner (below if you don't have it).
"Remove the cleaner head. Attach the Pool Pulse to the end of the hose and keep it under water. Turn on the filtration system.
• For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool Pulse is in the ideal range (when viewed from the side).
• For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
• For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the extension pipe, attach the hose end. Your installation is now complete."
http://www.baracuda.com/resources/manuals/PacerW83410.pdf
Dec 05, 2010 | Zodiac Pacer Pool Cleaner
I put the eyeball diverter on my pool and the cleaner runs up to it and the hose hangs on it. I keep my hose laying out strait when not in use. It does seem to stay on the sides also.
If the eyeball diverter is not working, you might need to install a wall climb adjuster (Part #K12065). This will keep the automatic pool cleaner on the pool's floor and walls and away from pool obstructions. Make sure the narrow end of the wall climb adjuster points down to the drive tubes.
Aug 23, 2010 | Universal Kreepy Krauly In-Ground Pool...
My Zodiac Pacer seems to get stuck. There is suction (pretty strong). It can happen on the side or floor of the pool. If I pull it off, it starts going again, it's like there's too much suction or...
It probally is to much suction. You should have a dirveter valve where it hooks to the wall or the skimmer. This should have come with the unit and your manuel should describe it and it's function for you. if you don't have one your local pool store can help you out as these are generic in most case's.
Sep 30, 2009 | Zodiac Pacer Pool Cleaner
JANDY RAY VAC won't back up
If you have a back up valve it will be about 18" from wall a small football looking thing this should cycle through about every munite or two and shoot a jet of water out the side of it for about 5-10 seconds if it dosen't do this pull it out of line and get a new gut for it. If this seems to be working ok you should be sure it has enough hose to reach the whole pool but be sure it just reaches the furthest point in the pool so it can strech the hose and remove any curls each time it does.
Jun 14, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Hayward Navigator gets stuck at wall
I have had the same Navigator for many, many years. I have replaced it's guts, pods, feet and gears whenever things wear out. I have a vinyl pool and it works great. I had a problem with it charging into the wall and just sit there beating it's feet ..... now this was my solution, and I'm surprised that Navigator has not altered the design to deal with getting stuck against a wall. This will sound CRAZY but it works great!! Take a plastic lid for a 5 gallon bucket and cut out a round-nose for the front of your navigator. The curved shape is prefect and you can notch the plastic lid and it will snug right into the Navigator body. This gives your Navigator a round-nose and it will never get stuck against a wall again.
Jun 01, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
825 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
