Home Security Logo
G
Gary tidymam Posted on Apr 21, 2016
The main unit red light is constantly on and the chime does not work
Ed Rutmayer
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Apr 23, 2016
Ed Rutmayer
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
1877
Points
25
This could be due to the wrong power supply. It's not enough to just match the voltage. You need to make sure the power supply can push the required amps ( or milliamps, or whatever).
If the power supply is the correct one then either the power supply or the unit itself has probably taken a dump.
No dash lights, chime is on without key in ignition(frequency changes when it is in) and no parking lights.
I took my a part and the plug is lose so we pull up on it and put a zipper tie and now it works fine
I recently wired a eonon e1091 into a 2007 silverado classic. i used a scosche wiring harness that allows me to keep my chimes. everything works fine but when i turn the truck off, theres still power...
It's called delayed acc. power. It should shut off as soon as you open the door. Unless the red stereo wire is hooked up to constant power. You may need to check with a test light.
Constant chime when headlights turn on.
CONSTANT CHIME NOISE IS WARNING YOU LEFT HEAD LIGHTS ON WHEN ENGINE OFF.SO YOU WONT RUN DOWN THE BATTERY.
5helpful
2answers
Two Red lights blinking constantly. unable to
Epson -R 230 desktop printer. Two Red lights blinking constantly on the control panel (beside main switch). unable to print.
44helpful
3answers
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
2answers
Red alarm light on constantly and heating wont work unless over ride system
Have you tried turning one of the thermostats off.? They are both talking to the same unit and they may be arguing with each other.
2answers
We lost are chime
Check to make sure you don't have anything that would impede the connection at the battery terminal
Aiwa CDC-X227 - No power to unit
Keep in mind that there are always two fuses in any vehicle that provide power to the radio. One fuse is for switched power, one for constant power. Both fuses need to be good before the radio will work. Often one of the fuses, especially the constant power fuse, is shared with other electrical circuits and may not be labeled as a radio fuse. Check all the fuses in the vehicle, including any fuse box under the hood. See if any other electrical systems in the car aren't working, especially the dome light, cigarette lighter, door chime buzzer, or clock.
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
