Too much yellow in the picture. The whites tend to be saturated with Yellow. Cannot fix with video men. I have tried all the adjustments color, brightness, etc. Color tends to have too much yellow.
    Sergeant:
    Champion:
  • 249 Answers
Problem with the monitor or RAM
Posted on Jul 17, 2009
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
How can i connect a video camera to play through tv. my camera cables are red-white-and yellow. tv. is white-red- green-green-and red.
Your camera has three cables, red and white for stereo audio, and yellow for what is called composite video. Composite video puts the three color signals into one composite signal. Your TV sounds like it has a component video connection, which wants all three color video signals separated onto three plugs. They are usually color coded green, blue, red. Not sure if you mistook a blue outlet for green..... In any case, on my TV, it will allow me to connect a yellow composite signal to the green component jack, the first (leftmost) of the three component video jacks. Not sure if your TV will work this way, but it is worth a try. Otherwise, you can look up accessories for your video camera and see if it can output true component video and stereo audio, but I tend to doubt it will.
Aug 27, 2014 | Televison & Video
There isn't a picture. I have tried to plug in the wire three separate colored plugs. The problem is I have a port for the white and red wires. I do not have a yellow port. I have tried to plug that...
Hello
White and Red ports are for Left/Right Audio. Yellow is for video. On the TV usually it would be a range of colors from Yellow-Green. Try looking for another port just for the video.
Good luck and please rate my answer.
Dec 17, 2010 | Microsoft Xbox 360 Console
My Canon G11 - most indoor pics have a strong yellow-orange hue. What can I do to correct this or is the camera broken?
Light from ordinary light bulbs has a strong yellow-orange cast, which our eyes tend to adjust for without thought. Check the white balance setting on your camera. This is to adjust the camera for the color of the light, to try to make white come out white, hence the name "white balance." Set the white balance to incandescent (light-bulb icon) for indoor shooting under light bulbs, or to automatic to let the camera take its best attempt.
Try experimenting with the white balance setting. Taking pictures in bright sunlight with the incandescent setting will give your pictures a very blue cast, making things look a little colder. There are other settings, such as flourescent.
Sep 19, 2010 | Cameras
I have a problem I am trying to connect my dvd player It shows black and white i have a proscan 32 inch what can I do to fix this ? please help.
Check to make sure the Video connector (YELLOW) is connected to a YELLOW plug on both the TV and the DVD. If it is plugged into a GREEN plug then it will produce the black and white picture and not a color picture.
Good Luck...
Feb 24, 2010 | Proscan PS32700 32" TV
Bad yellow cast to photos when printed
If you have a yellow cast to your photos, the problem might not be your printer. If you're using a digital camera, indoors under incandescent lighting without a flash your pictures will look yellow.
If this is the case, set your camera's White Balance to Incandescent lighting or use the flash. If all of your pictures, even those taken in daylight, look yellow you'll have to adjust the colors on your printer using the "toolbox" software that comes with it and back the yellow off. I've found that HP printers tend to have better color rendition than Canon.
May 24, 2009 | Canon Office Equipment & Supplies
Yellow tint in photoshop
Try adjusting the brightness on the monitor
Feb 27, 2009 | Adobe Photoshop® CS3 Extended Full Version...
PS2 screen won't show on tv set to game
try to trouble shoot if the wire is the problem, how? remove the 3 colored wires from the tv and ps2 then try to use the red color instead of yellow to the video from tv and ps2 (both red) temporarily do not use the yellow color. once a picture appears use now the white for the audio (both white) for left audio once there is a sound you may try the yellow for the right audio. i hope this will help you and hear a positve reply from you.
Dec 03, 2007 | Sony PlayStation 2 (PS2) Console
No contrast
first turn your color all way off or down.try turning your contrast way down as far as it will go you should see a darker picture. now bring up the brightness to a point half way. bring the contrast up to see grays and whites and blacks...adjust brightness more if need be. now you should see a nice black and white picture. no bring your color up last ...not saturate but to your liking. if you stilll got problems i bet your video out transistor is shorted....meaning shop work.
Aug 31, 2007 | Panasonic PT-51HX41 51" Rear Projection...
White balance
Use real color mode, saturation set to normal.
Sep 13, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
