Warm Method
Both Good Housekeeping and the website Hunker describe this method for self-cleaning ovens. Hunker warns to NOT use the "cold method" which is reserved for other types of ovens. And the Good Housekeeping site says if the method proves unsatisfactory, that the floor or bottom plate of the oven might have to be replaced.
(That said, I suspect if you pull out oven racks and apply some ice to any plastic on it, the plastic might become brittle enough that tapping it with a spoon and prying at it with something wooden or finger nails might remove a lot of it. No scraping with the spoon!)
Here is the primary process for the oven.
Self-cleaning ovens require heat to remove the melted plastic. This method also works on heating elements with plastic on them.
Step 1
Turn the oven on to the lowest heat setting. Only leave the oven on long enough to make the plastic soft and pliable.
Step 2
Scrape the melted plastic with a wooden utensil such as a spatula or spoon. The wood protects the surface inside the self-cleaning oven. When you get all off that you can, the self cleaning feature may burn off the rest. That WILL be smokey and exude an unpleasant smell while it does it. Open windows and keep pets out of the area (and yourself) while it goes through the clean cycle. Do NOT use a screw driver to try and remove the plastic.
You will need to physically remove as much as possible. A plastic putty knife or similar will work best. Use a hair dryer to gently heat the plastic to make it pliable and easier to remove. The oven will need a thorough cleaning once you have removed as much plastic as you can.
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
on the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
Cheryl, If you can't scrape the plastic off then heating it up to soften it is about your only choice short of putting it back in self clean with a fan in the nearest window blowing outside to evacuate the smoke. Depending how bad it is and how cold it is where you live, you might even try freezing if off. Get it as cold as possible and see if the cold makes it easier to chip off. As far as the element, I suggest turning the oven on and letting it smoke and burn clean. Shouldn't be a very long process since the element will get hot so fast the plastic will drip off right away. Hope that helps... Brian
You can remove the bottom oven panel and look under it. All you have to do is remove the oven racks and locate the screws that hold the bottom panel in place. MOST ovens only have two of them. Once you have the crews removed, the panel slides back a bit, then lifts up. If there are any heavy deposits of melted plastic, remove it like you did before. Any residual material can be taken off with some fine emery paper. Wear a dust mask and vacuum all the dust out of the oven. DO NOT use this method on the oven wall as it may scatch it. This is only for anything that may have dripped below the oven pan. You may have an odor to the oven for a while, but as long as you have nothing else melted inside this should go away. Try running it on a cleaning cycle AFTER you've inspected the oven & cleaned out the remaining plastic. This will burn off anything left behind. I hope this helps you.
self cleaning is sometimes a cycle called PYRO clean / look for the setting with a really high temp. self cleaning is a programmes require a massive amount of heat and will smoke a lot when on , so dont be alarmed! most oven when on self cleaning mode will automaticly lock the door due to the high heat involved in the process. so remember to remove pans etc. from inside.
