Question about Cambridge Soundworks BassCube 12 Speaker
Basscube 10 dead...need zener and resistor help
My Basscube 10 died suddenly and I finally got around to taking it apart. Like a few others, I discovered that the board was burnt around the four zener diodes and the R63 resistor. Someone identified the zeners as 15V and the resistor as 1200. I am trying to purchase the correct replacement parts from Mouser but there are further identifying characteristics. What should the power dissipation and current be for the axial zeners? What type of resistor should it be such as carbon composition, film, etc and what should the wattage and voltage rating be? Any assistance would be greatly appreciated!!!
  • tmannesto Jul 17, 2009
    After pulling one of the zener diodes from the board I was able to identify it as 1N4744A. A Mouser techie advised that a 15V 1W zener is a suitable replacement. Still working on the resistor.
  • 3 Answers
I had a similar problem with my basecube 12. around the zener diodes and resistors looked Burt out on the circuit board. i replaced all those components including resistors, zeaner diodes and capacitors in the area which didn't fix the problem. it wasn't until i replaced the big 6800uf 50v capacitors did the problem get solved.
Posted on Jan 24, 2013
The zener diodes are 1N4774, I believe they are one watt. Try 3 watt metal oxide for the resistors. You might as well replace the 6800uF 63 volt main filter capacitors and the 220uF 50 volt capacitors while you're at it. Half the time the heat that cooked your other parts takes them out as well.
Posted on May 26, 2011
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
Motorola triumph won't charge when plugged in
I tried everything, bought 3 new batteries, 4 new chargers and everytime about a day goes by and the phone dies in less then 3 hrs and stays dead...tried connecting to usb, tried removing the batter and still dead...finally followed the steps on the website: https://motorola-global-portal.custhelp.com/app/answers/prod_detail/a_id/83322/p/30,6720,8064 first I held down the power and lower volume buttons for 10 sec. and no luck, removed the sd card followed by downloading the manager and motocast from the website above and finally...looks like the charge light finally turned back on...Finally guess this is what it needs with all the downloads and memory used i need to keep it up to date....I guess...hope this helps others...i was ready to tear this phone apart and just buy a new one...just saved some $$
Jul 27, 2012 | Motorola Mobility Triumph WX435 Cellular...
How to adjust the dead key in a uniden pc78ltw
You change the dead key with the addition of 2 components to the board. There is no dial or pot inside to turn to adjust the dead key.
What you want to do to the radio is called a swing mod. If you are trying to adjust your dead key, it sounds like you are trying to run a linear amplifier. If that is the case, you should probably set your dead key to around 2 watts. Most amplifiers are good with 2 watts. If this is so, then do this:
Go to radio shack and get a 1/2 watt 100 ohm resistor, and a 100uf 35 volt electrolytic capacitor.
Open the radio and look for JV117. It is a jumper. It is located in the back left of the radio in front of the final resistor in front of the heat sink.
Use a de-soldering wick to remove the solder from the trace side of the board. Remove the jumper.
In the jumpers place put the capacitor. Make sure the black tab is facing the back of the radio, towards the final. This is very important because there is a positive and negative to the capacitor. If you do it backwards you can blow your radio.
Solder in the capacitor, then take the resistor and on the side you soldered, solder the resistor bridging the 2 pins of the cap on the trace side of the board.
How this works:
The resistor determines the amount of dead key. the bigger the resistor, the smaller the dead key, the smaller the resistor, the higher the dead key. (dead key will only go as high as it was before you put in the mod.) A 100 ohm resistor gives you about a 2 watt dead key.
ALSO! you are going to want to find VR4. Its a little pot towards the back right center of the board. Then turn it all the way to the left. This turns up your modulation, and will make the radio swing to full PEP wattage, around 20 watts.
If you have a watt meter that reads avg wattage then you can gain more wattage by adjusting L14. It is just right of VJ117. it is a white or brown plastic tank with a copper coil around it with a slug in the center covered by a little way.
*do this only if you have a meter, also, do not transmit on your radio without an antenna connected or a dummy load or you will blow the final.*
Remove the wax and then while saying a steady ahhhhh sound, slowly back out the slug until you have peak wattage,(when the needle no longer increases.) You do not want to back the slug out any more then is needed for full wattage, other wise you over bias the final and lessen the life of it. So once the needle stops going up while giving a steady ahhhh into the mic, back it in a hair just to make sure its not over biased.
And as always, if you are not comfortable doing this your self, take it to a radio tech at a radio shop. They are usually found at truck stops.
Oct 15, 2009 | Uniden Radio Communications
Rancilio Rocky is dead
Hi. I had the same problem. Called my trusty local repair guy who said spray a little canned air around the front switch (without taking anything apart). I carefully cleaned around the switch, since this problem is caused by dirty connections behind the switch, then I blew a few blasts into the cracks. Presto! The machine works. Repair guy said sometimes the switch goes bad, too, and needs replacing.
Apr 12, 2009 | Rancilio (RAROCKYND) Grinder
Sony Trinitron (analog) picture suddenly ''pulsating''
the verticle has a problem check the following around that area
capacitors
zener diodes
resistors changing values
what is happening is that a voltage is not constant, its varing
Mar 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
AKAI TV Repair Question
If Z3 was shorted, there are 2 surface mount resistors that were damaged when Z3 became shorted and they have to be replace as well. The reference designator for the resistors is R65A and R65B, their value is 10 ohms and 1206 is the body size of the resistors.
Jan 16, 2009 | Akai LCT2701TD Television
Cambridge Soundworks Basscube 12S only makes pulsing buzz noise
Hey! So i fixed my problem! This is for the BassCube 10
Like i said before i saw that the circut board was burnt near the diodes ZD3 & ZD4, and the resistor R63. Thanks to Deadly1 and BillRad62, i figured it out. The R63 is a 1200 resistor, and the diodes are 15v zeners. I went with 3x 5.1v zeners to replace ZD3, unfortunately Rip-Off-Shack (Radioshack) didnt have 3 packs of these so for the ZD4 i put a 12v and 5.1v. Which exceeds 15, but seems to work without a problem. Hope it helps!
Dec 13, 2008 | Cambridge Soundworks BassCube 12 Speaker
HP Compaq FP5315 15" LCD Monitor dead
yeah replace the caps and sometimes the 7.5v zener diode burns up too. I have been replacing the surface mount ones with just a regular through diode
Jun 11, 2008 | HP Compaq FP5315 15" LCD Monitor
HP ppp009 laptop power supply
The best way is to get one off ebay by part number. Take it apart and write them down. Then order the resistors and you will have 2. Then you can either sell the other one back or keep it. You cant lose if you have electronics skills.
Dec 31, 2007 | HP Compaq NC6400 Business Notebook
No sound No picture slight but audible buzzing in flyback. That says it all. Fuse is OK Brown on circuit board around Large heat sinked transisters. "assumption these may be regulators" Can not...
Take it apart and check the low ohm resistors around the flyback
and see if your horizonal Transistor is short,Do a diode test on the juntion of the Horiz-transistor does it read low ohms from collector to ground,with set unplug.Let us know
May 11, 2007 | Emerson EWF2704 TV
Open Questions:
See all Cambridge Soundworks BassCube 12 Speaker Questions
Cambridge Soundworks BassCube 12 Speaker Logo
956 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
