Question about Refrigerators
Freezer is working fine. The fridge is not getting cold on level 3 thermostat setting. We have to set it on 5 (Coldest) to get a satisfactory cool level. On 3 which it has been set on since purchase in 2000, the milk goes sour. Help us please!
  • 1 more comment
  • ljstavropoul Jul 17, 2009
    This is a double door Whirlpool Gold fridge/freezer. the model number is gd25dfxfw02. The serial number is sk1047786 and the mfg date is 03-00. The fridge side of the fidge/freezer is the problem child. thank you!
  • ljstavropoul Jul 19, 2009
  • Mike Smith
    Mike Smith May 11, 2010
    What brand and model number ?
  • 82 Answers
Look at the back of the freezer, if there is frost on the cover, there is probably a defrost problem. if you can unplug it and let it sit with door open overnight, if not remove all food and back cover. use a blowdryer to melt the frost on the coils, probably needs defrost thermostat.
Posted on Jul 17, 2009
The fridge is not cooling, but the freezer is
could be several things wrong. I'll start with the simplest first. Its possible that you have the thermostat set to the coldest setting. and what his does is actually close off the damper and prevents cold air from entering the fridge. the freezer will be colder because no air is entering the fridge. If you do not have the thermostat set to the coldest setting, let me know and we can go to step 2. at least this way we ca eliminate each step 1 by 1 to get this fixed for you.
Feb 03, 2011 | Refrigerators
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
My fridge isn't cold.
so get the gas filled in ur compressor
Jun 25, 2009 | Refrigerators
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Oct 10, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Refrigerators Logo
145 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
