HP Photosmart 3310 Printer Logo
Posted on Apr 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't print on photo paper from picassa file
It prints from memory cards but not from desktop picasa file
Electro Med Services
Level 3:
  • HP Master 6,694 Answers
  • Posted on Apr 21, 2016
HP Master
Level 3:
Answers
6694
Questions
Helped
1872476
Points
21433
Try to reinstall the printer software on PC.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
1helpful
How can i get my photo off the camera on to the cmputer then print them
The best way to download photos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy photos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Picasa will also do a more than adequate job of printing your photos.
2answers
Cannot print
can u printh photos from other places?
How do I transfer photos from picassa to a memory stick ?
PICASA application don't have any image on it all the images are on your HDD. You just need to locate them and then copy them to your memory stick normally like you copy one file from other location.
For locating the image try to find the path of the image into picasa by right clicking or viewing the properties of the image.
Adapt vivicam8320 to compter vieu pictures then print
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery or Picasa ( http://picasa.google.com ).
Any of the above-mentioned programs, or any other photo cataloging program, will let you print pictures (assuming you have a photo-capable printer).
How to use photo feature on Lexmark Impact S305
1. From the printer control panel, press the Photobutton.
2. Insert a memory card, flash drive, or digital camera set to mass storagemode.
If document files and image files are stored in the memory device, then pressthe arrow buttons to select Photos, and then press OK.
3. Press the arrow buttons to scroll to Easy Photo or Print Photos, and thenpress OK.
Notes:
• Select Easy Photo if you want to print photos quickly.
• Select Print Photos if you want to customize the photos before printing them.
4. Press the arrow buttons to select a photo printing option, and then pressOK.
Note: You can choose to print the most recent photo, print all the photos,print photos that fall within a date range, print photos by selecting the photonumbers on a proof sheet, or print pre-selected photos from a digital camerausing Digital Print Order Format (DPOF). The DPOF option appears only whenthere is a valid DPOF file in your memory device.
5. Adjust the print settings:
• If you are in the Easy Photo menu, then press the arrow buttons to select thepaper and photo . Press OK each time you make a selection.
• If you are in the Print Photos menu, then press the arrow buttons to selectthe photo , paper , paper type, layout, photo effects, and quality ofthe photos, and to adjust the brightness and color effects of the photos. PressOK each time you make a selection.
6. Press the Color/Black button to set a color or black-and-white print.
When you select color or black-only printing, the light near your choice comeson.
7. Press the Start button.For more info, you can also check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > S300 Series > View User's Guide.
1helpful
2answers
I don't want my Picasa web album on my Samsung I9000 gallery, can this be removed?
Picassa web album is an inbuilt application in Android OS to browse the photos if you remove it you be unable to view the photos, but if you still want to remove the picassa application you can to to Settings>>Applications and remove the inbuilt applications.
Regards,
Sagar M
Using lexmark x4580 how do I print smaller photos on A4 paper from a email which has 18 pictures in total I wish to print 6 or 8 to a page. Thank you dustyvrn
You can use a free program called Picassa to do this.
See this link.
http://www.ehow.com/how_2042544_print-contact-sheet-using-picasa.html
I have just installed my C5580 printer and every step was perfect. I printed a picture from my library- no problem. I inserted my camera memory card and printed a picture - no problem. Then I went back to...
what PC, HP, then what HP model
what OS< what operating system. on that PC.
did install the C5580 software, packing from HP.com
matching your OS?,
how is the 5580 connected to that PC.
USB connected?
Or blu-tooth connected.\
the manual.
http://h10032.www1.hp.com/ctg/Manual/c01507549
the software is here.
XP throught a w10 software is here, match what you have.
https://support.hp.com/us-en/drivers/selfservice/hp-photosmart-c5500-all-in-one-printer-series/3575176/model/3575255
if running XP, make sure SP3 is installed, service pack3
if USB fails try different USB port on that PC.
1helpful
Printing Problem
my laptop sony vaio vgn-n130g it is do not work LCD back light in press (Fn and F5- F6+)
1helpful
Printing Problem
You may have a problem with your magenta color cartridge ????
k24674
Grand Canyon Tech
Grand Canyon Tech
