Question about LG Electronic Window Air Conditioner
We bought an LG Electronics LT1030CR Air Conditioner about 2 months ago. Since the beginning the thing has been make this grinding noise every minute to minute and a half. We moved it around, made sure it was balance, made sure that nothing was touching the back (which has for of the back stuff esposed but with like a fence I guess is a good way of describing it) but anyway nothing is touching and it is still making that awful grinding noise. Does anyone know what could be wrong with it.
  • lightenmd89 Jul 17, 2009
    Ok so it's the compressor. But what's wrong with it? What am I suppose to do to it or with it?
  • 867 Answers
Well, rattling noise would be something loose, actual grinding noise would be the compressor,
Posted on Jul 17, 2009
  • Buckleroy May 30, 2011
    Same problem with 2 new units. I investigated and found that the fan is rubbing against it's housing. The housing is made of plastic and isn't attached at the top and consequently it deflects (sags) and rubs against the moving fan blades. It is a bad manufacturing decision and I don't have the time or experience to fix it. The BAD decision to make a structural part of the air conditioned out of plastic and hold it in place with double stick tape should be solved by a recall by the manufacturer.
I got a new (out of the box) LG window unit about a month ago and about a week later started making this awful noise that would wake me out of a dead sleep. It happens about every 10 minutes and I'm at...
compressor fan blade stripped out,,and the motors shaft is slipping..LG uses plastic fans ,,Ive replaced 4 on mine in the past 5 years,,,,part around $30
Aug 26, 2011 | LG Electronic Window Air Conditioner
Tip
LG LT1030CR air conditioner User Manual(PDF)
Hello
Sometimes it is very useful to have an soft coy of a user manual at hand to use when you do not know the exact steps to change a certain function, or enable anther.
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click HERE to find out exactly how to download the manual. The above mentioned link will explain step by step how to download the user manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product. You will also be able to upload a user manual which this website does not have.
Click HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit LG's official website for news on their latest products. You will also be able to download updated firmware for your device. Click HERE to find out how to update your firmware.
I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
on Mar 10, 2010 | LG LT1030CR Thru-Wall/Window Air...
MY LG 2 TON INDOOR UNIT MAKES NOISE AFTER 2 HOURS OF STARAT FOR 20 SECONDS AND SOUND DISAPEARS ITSELF BUT AGAIN AFTER 10 MINUTES NOISE REAPEARS AND SAME SITUATION CONTINUES TILL ITS COMPLETLY SWITHCHED...
The compressor is locking up....the start relay and capacitor maybe the problem...I would have them changed first and then if that don't help the compressor will need to be changed out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 08, 2010 | LG Heating & Cooling
My LG LWHD 7000 is not heating.
heater coil located behing the front evaporator coil has burnt out. To access the coil you need to remove the a/c from its sleeve and the coil is located between the evaporator coil and the fan motor. An appliance parts house will have the replacement coil if you do it yourself.
Good Luck on your repair hope this helped
Dave
Jan 07, 2010 | LG Heat cool Window Air Conditioner
Air Conditioner just stopped working
verify that the fan is free to spin and not binded, window units are bad for this due to close tolerances in the small cases
Aug 10, 2009 | LG Electronic Window Air Conditioner
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
Ac do not drop down the tempture of room.
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Jun 25, 2009 | LG Heat cool Window Air Conditioner
LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Jun 05, 2007 | LG LSC121PMA Split System Air Conditioner
LG Electronic Window Air Conditioner Logo
424 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
