Question about Refrigerators
Kenmore colspot freezer drain line keeps freezing
Kenmore coldspot freezer drain line keeps freezing up and water overflows into refrigerator
  • Anonymous Mar 13, 2014
    Need location of drain for freezer in sears coldspot series 66741
    President:
  • 1,136 Answers
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 17, 2009
Kenmore coldspot refrigerator model 7016299 freezer not freezing.
Check the drain line, defrost heater, and limit switch.
Feb 21, 2015 | Kenmore Refrigerators
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Condensate drain inside of freezer compartment keeps filling up and freezing and then overflows to bottom of freezer compartment and freezes. Have made sure drain line is clear. Problem occurs about every...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 22, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore Coldspot ref, model # 78862898. The freezer literally has icicles hanging from the roof of the freezer, frost on food items. The ref isn't as cold as it should be with water...
Sound allot like there is a serious air leak....Is the door sealed good? You also have a defrost drain line plugged up behind the freezer panel you will need to clear that out with hot water after removing all the ice. watch this video to see how to replace the defrost thermosthttp://www.youtube.com/watch?v=z-h541_14ZE
May 26, 2011 | Kenmore Top Freezer Refrigerator
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I have a 10 yo kenmore coldspot refrigerator. We
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Jun 30, 2009 | Kenmore Refrigerators
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water pooling and freezing inside bottom freezer.
make sure you have cleared the drain all the way to the drip pan, and the fridge should be tilted slightly to the rear for good drainage........make sure there is a clear path for the water to make it to the drain hole
Jan 03, 2009 | LG LFC25760 French Door Refrigerator
Refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Mar 11, 2008 | Refrigerators
Kenmore Coldsport freezer drain repeated freezes
probably the easiest fix for this is install a drain probe to transfer heat from the defrost heater into the drain hole to prevent ice build up. take a peice of 10 or 12 guage solid copper wire and wrap one end around the defrost heater pretty tight and put the other end down in the drain line 2-4 inches.
Dec 15, 2007 | Refrigerators
Refrigerators Logo
613 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
