Question about Sony Handycam CCD-TRV318 Camcorder
C:31:23 code with flashing icon for eject,with a beeping sound
Every time I go to record or playback the camcorder does so for about 3 seconds,then I get this code with the flashing icon to eject along with a beeping sound. Sounds like this is a very common problem.
  • Sony Master
  • 497 Answers
The error message indicates that the Camcorder has detected an issue that may require a power reset.
Step 1:
Try to reset the Camcorder and check if it helps to resolve the issue. Locate the RESET button behind the LCD screen of the Camcorder.
Step 2:
Turn off the Camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter.
Step 3: If still unresolved Service may requires.
Posted on Jul 17, 2009
  • lucho0019 Apr 19, 2011
    THANKS FOR THE ADVIDE MAN. IT REALLY WORKED
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
URGENT NEED HELP WITH C:31:23 CODE ON DISPLAY SCREEN
Try first removing the battery and see if this clears the error.
Aug 24, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Icon
The icon you see is "EJECT" tape. It shows there is a problem with unit but cannot be defined without having unit checked by a pro tech
Apr 06, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-IP7E Micro MV Digital Camcord
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Nov 03, 2007 | Sony Handycam DCR-TRV250E Digital...
Image and sound problems at playback
your tape guides are out of calibration on all your pre - recorded tapes , or they are out of adjustment ( maybe even loose ) now ; - - put your camcorder close , next to your ear ? and . . . listen ! to a new tape in play mode - if you hear a fluttering sound like a deck of cards being shuffled softly , the camera is damaging all your tapes and needs alignment ;
Jul 28, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Jun 15, 2007 | Sony Handycam CCD-TRV37 Camcorder
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Sony Handycam CCD-TRV318 Camcorder Logo
539 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
