2005 Dodge Ram...... A C unit is cold but the air on high is like its on low, the sound changes with each setting like it wants to blow harder but not that much comes out, it does blow a little harder on high over the lower settings but in the heat of the day it cant cool the cab.
  • billssf49ers Jul 17, 2009
    the air is cold just not much coming out of vents.
    we will see
It could be the connectors on the high pressure switch above the a/c compressor..or the A/C might need gassing...could be a fuse...wouldn`t think it is a hose ..also you could check the inlet/outlet pipes on particle filter..(passenger side rear of engine bay black cylinder) should be warm and cold but not frozen..if it is frozen while a/c is running then is probably that the high pressure switch was disconnected.
Posted on Jul 17, 2009
  • 3,741 Answers
Check out the coolant in the box.is it properly filled or end.also check out if the gas bottle is properly tight and nothing is loose.also check if the air is getting leaked from any where between gas bottle pipe to coolant from under the front of the car.also check out if compressor is getting hot .if the fan is not spinning the fan is the problem.but if fan is spinning then also hot the compressor is faulty.this has to be checked.most probably as the systoms you have mentioned the compressor is looking faulty as its blowing harder but not much cooling is coming. get all this checked. this will help. Please do rate the solution. Thank you for using fixya.keep updated. thanks
A/c blows cold and hot air intermittenly. sometimes when i rev the motor, cold air comes back.. whats wrong?
FROM WHAT YOUR SAYING IT SOUNDS LIKE THE FREON IS LOW. HAVE U HAD IT CHECKED SINCE U OWNED IT. IS THE COMPRESSOR SHORT CYCLING(CLICKING ON AND OFF)
Aug 12, 2010 | 2005 Dodge Ram 1500
2001 dodge 1500 pickup. The air conditioning
It sounds like a low charge. It could be a clogged expansion device also. It has a higher probability of being a low or contaminated charge.
Jun 23, 2010 | 2001 Dodge Ram 1500 Truck 2WD
A/c not blowing hard
the blower motor may be bad but check the blower resistor,if its bad it will work only at low speeds.
this is what it looks like
Sep 08, 2009 | 2005 Dodge Ram 3500
Air conditioner doesn't blow with much force
Refrigerant is not your problem!!!!!!!!
Your recycle door has broken off and fallen over the suction duct to your blower. You can verify this by removing the blower under the dash on the passenger side. Reach up into the duct and if there is a plastic door obstructing the duct, it has broken off. With a little manuvering you can remove the broken door through this hole and you will have air again, just no control of inside or outside air. Dodge has redesigned the housing for this recycle door which is supposed to stop this from happening. The redesigned housing and door come as a unit from Dodge for about $30.00 and this includes the electric actuator. This requires removing the Dash to change the housing so if your not ready for several hours work, take it to a mechanic.
Jul 14, 2009 | 2005 Dodge Ram 3500
A/c on dodge ram 2500 not blowing cold air .. pressures have be checked low pressure side high doesnt need to be charged that was checked also
is low side pipes cold?,is it sweating good<is evap.core box leaking condensation? if so u have a temp door not moving inside
Jun 29, 2009 | 2004 Dodge Ram 2500
Dodge Ram 1500, air will blow when switch in high position.
Check the blower resistor for burned or damaged coils.
Jun 16, 2009 | 2007 Dodge Ram Truck
The heater is blowing cold but the engine temperature reads high
Hi
I would first check to see if both heater hoses are hot to the heater.
if 1 is hot and 1 is cold the heater control valve is closed or the heater core is plugged.
Jan 14, 2009 | 2005 Dodge Ram 1500
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
