Question about Sony Playstation 3 (PS3) Console
Do you know where can i get the red n black thin wire that is connected to the drive board
  • 198 Answers
I know the wires you're talking about.
You can look around and see if a friend or whatever has a broken PS3, then you can snag the wires off of those. That might take a while, as the models of the PS3 differ.
If you have no luck, you can take it into a specialist and they can repair the connection.
It would be cheaper than sending it to Sony.
Plus you voided the warranty by opening it up in the first place.
I'd say don't touch anything else. Unhooking more wires could make your Blu-Ray inoperable. Even if you connect everything back real snug.
Posted on Jul 17, 2009
Have a 1994 Dodge Ram 1500 4x4 1500 with wiring problems. The original problem was a brake light out on the drivers side. I changed the tail light plugs. With head lights off I had brake lights with head...
Your truck may have had the factory trailer tow package, but that did not come with a wiring connector in that year. There should be a wire harness under the rear of the truck near the center of the bumper with 7 wires of the following colors/characteristics -
Red/Orange - +12V Battery (Thick Wire) From fuse #8 (40A)
Black/Orange - Tail Markers (Thick Wire)
Light Blue - Trailer Brakes (Thick Wire)
Violet/Black - Backup Lights (Thin Wire)
Dark Green/Red - Left Stop/Turn - (Thin Wire)
Brown/Red - Right Stop/Turn - (Thin Wire)
Black - Ground - (Thick Wire)
Under the dash, the brake controller wiring should be -
Black/Orange - Ground - (Thick Wire)
White/Tan - Brake Light sense - (Thin Wire)
Hope this helps.
Mar 19, 2013 | 1994 Dodge Ram
Tip
How to measure Voltage in Transforme for Fitness Treadmill
Transformer Test Procedure:1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow
Transformer Test Results :1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and power to the drive board. 2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
Transformer Wire Colors Normal Voltage Value:
Red and Red 110 VAC.
Black and Black 11-13 VAC
White and White 11-13 VAC
Orange and Orange 27-29 VAC
Yellow and Yellow 10-12 VAC
on Oct 26, 2011 | Exercise & Fitness
Tip
How to measure Voltage in Transformer for Fitness Treadmill
Transformer Test Procedure 1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow.
Transformer Test Results:1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and powerto the drive board.2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
ValueRed and Red 110 VAC
.png
ERNESTO CUADRA
MANAGUA, NICARAGUA. C.A.
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Had to change tower looking for the layout to connect the front usb wiring to the board , need to know which wires go on the board
motherboard usually red-white-green-black
Standard USB Cable Wiring Color Code
5V / Red
D+ / Green
D - / White
Ground / Black
hope this helps
Mar 31, 2011 | Intel Motherboard
BACK PANEL OF CAR MP3 PLAYER UNDERSTANDING CONNECTIONS. i'VE JUST BOUGHT A CHINA MADE CAR MP3 / FM PLAYER. IT'S BACK SIDE HAS GOT 2 SETS OF SPEAKERS CORDS. ONE BLACK CORD LOOKING LIKE AV CONNECTION JACK...
from what you describe, the red wire is definately power in to the unit ((+) hence the fuseable linkage). Blue is an odd color in electronics, so if its next to the red it is more than likely return voltage ((-) in DC circuits return voltage is grounded. Typically a head unit will have the wire diagram printed on a sticker placed on top or the back of the unit.
AND FOR THE BLACK CORD, thats for then fm antenna, there should be a cord that looks just like that one behind the unit, only the vehicle end is the male end.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Jun 05, 2010 | Car Audio & Video
Precor 9.25i treadmill running backwards.
The power leads Black/red will determine the direction that the motor will turn. If the leads have been switched to the wrong terminals at the lower PCA it will run backwards even if the black and red line up when the motor is plugged in. Check to see if the power cable on the lower board is in the right configuration. I've seen the terminals get switched when a new lower board is installed.
Oct 07, 2009 | Precor Exercise & Fitness
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
Front light jumper cable
If it has the black and red wires, it connects into JP2.  The other wires, which are black and green connect directly to the power supply into connector CN4. Bob
Apr 04, 2008 | EZQuest Cobra Plus (B66600) 80 GB Hard...
Sony Playstation 3 (PS3) Console Logo
88 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
