When i plug my verbatim USB portable hard drive into my hp pavilion 501a windows xp it does not come up any where The lights are flashing on it but no icon on desk top and its not in my computer. I have no trouble using it on my laptop vista windows .I just carn't get it to come up on the xp
  • Bev Denniss Jul 17, 2009
    When i turn computer off plug in verbatim&turn back on there is a portable G in my computer to open this it say's to insurt a disk.now when i go to admin tools ,computer manag. disk manag.i have Disk 2 removerable G with No media writen under neath it.If i right click to change Drive letter and Paths for G:0 the box comes up With a Picture of portable Disk Device and letter G. Now I do not Know what to do from Here.
    Scholar:
  • 119 Answers
Greetings,
A couple of things could be wrong...
  1. There is a problem with the USB port on your Windows XP box
    Possible Solution: Plug the hard drive into another port to see if that helps.
  2. The USB drivers are not registering correctly
    Possible Solution: Plug in hard drive while computer is off and then boot with the hard drive connected and on.
    Possible Solution: Check for and remove the USB Mass Storage Device inside of device manager under the USB devices section
  3. Windows is having problems assigning it a drive letter
    Possible Solution: Go into device manager, administrative tools, computer management, disk management
    Check for the hard drive there. It might be listed without a drive letter. You should be able to right click on the partition for the drive and assign drive letter.
I hope this helps! Please let me know if you need clarification.
Best Regards,
Posted on Jul 17, 2009
  • Aaron Monello Jul 17, 2009
    It's good that you can see a drive letter for it. It almost sounds like XP does not like the format of the driver.
    Is it possible to move the files (to your vista computer) from the portable hard drive and try to format the drive on your XP box?
    If you can format it on the XP, the Vista machine will read it. Sounds wacky that this could happen but since it works on your Vista, that tells me there really isn't a problem with the drive.. the problem is with the XP box.. formatting the drive seems to be the easiest option as well as quickest to see if XP can see it ok.
    Comment back with your progress!
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
What Windows-compatible "backup" software can
You can format it directly from Windows XP going in My computer then right click on your drive icon and hit format. Don't change anything in the fields but put a check in quick format.
For your backup needs, Acronis are making very good data management softwares.
Feb 10, 2011 | Verbatim 160GB USB FireLite: The "drive...
Does this unit work on windows 7
Yes, because it is a "plug-and-play" device, and Windows XP/Vista/7 support "plug--and-play".
Nov 29, 2010 | Verbatim 320GB USB Portable Hard Drive
Verbatim store-n-go 8GB usb drive is not recognized by windows XP?
Contact Verbatim for a solution, these USB flash drives have lifetime warranties!
Aug 24, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
Blue light flashed on the portable hard drive for a couple seconds.How do I know if all files were transfered? Nothing on screen showed up? I have a HP laptop.
If your portable hard drive was set up as the "H" drive, go to My Computer (in Windows XP), or Computer (in VISTA), select your "H" drive and view your files (if there).
Jun 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
When I plug my portable hard drive into my computer it flashes
i speak only a little english. my problem is the next : i can´t see the portable hard drive in my pc ( windows xp ) . i would like to know the answer to this problem. thank you
Nov 18, 2008 | Verbatim SmartDisk Firelite Portable USB...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
