Televison & Video Logo
F
Fooman Posted on Apr 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba 37 inch flat screen 37AV502U keep turning itself on then off randomly. Any ideas what it could be?
Started randomly turning on then off, now the television will not stay on. Model 37AV502U
Electro Med Services
Level 3:
  • Toshiba Master 6,694 Answers
  • Posted on Apr 20, 2016
Toshiba Master
Level 3:
Answers
6694
Questions
Helped
1870170
Points
21433
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
It seems like the volume down button is stuck. As soon as you power on the set it turns the volume down all on its own. I've check the button itself and removed the batteries from the remote. Don't know...
Try some contact clean on the Vol- and Vol down contact switches,either the Vol- contact is dirty or it needs to be replaced. Mats Electronics has contact switches 1-800-628-1118
You could have a problem with Poor Solder Connections on Boards.
Loss of favorite channels when tv is turned off. This is a 37" Toshiba LCD tv.
Redo it again lost power to tv,sometime loss Data save.Data dossn't dissapper only lost.
1helpful
Screen displays not available eventhough the video
The main board has become faulty. The logic in the TV is bad that is causing the TV to have such problems. The only way to fix is to replace the main board.
I have sound but no picture on my toshiba flat screen
Hi...
What are you using for cables to connect to the TV?
Can you try a different one?
Let me know
There is one red line from the top to the bottom of my TV screen.
This is a problem with either the processing board or the panel itself. If the set is only a few weeks old, you should be able to return it for an exchange. These things happen to these sets on occassion. Just request an exchange under warranty.
Dan
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
