Question about Gateway Computers & Internet
0x0000007b (0xf78d2524, 0xc0000034, 0x00000000
Boot up my gateway laptop operating system not fould. put in windows xp disk i get stop 0x0000007b (0xf78d2524, 0xc0000034, 0x00000000 0x00000000 )
  • 497 Answers
Try resetting the BIOS to default. or
1. On start up, press the F2 or 'Delete' key to enter the BIOS menu.
2. Expand the "Drives" section
3. Go to "SATA Operation"
4. Change this from "RAID Auto/AHCI" to "RAID Auto/ATA".
Posted on Jul 17, 2009
This also works for Gateway PCs. The only difference is that you change the RAID setting from RAID to IDE
Posted on Jan 11, 2010
Stop:0x0000007b
Hi Jefferson,
  1. Did you just install or make a change to a hard drive controller? If so, there's a good chance that the change you made caused the STOP 0x0000007B error.
    Undo the change and test for the 0x7B blue screen error.
    Depending on what changes you made, some solutions might include:
  2. Verify that the SCSI chain is correctly terminated, assuming you're using SCSI hard drives in your computer. Incorrect SCSI termination has been known to cause STOP 0x0000007B errors.
    Note: Most home computers don't utilize SCSI hard drives.
  3. Verify that the hard drive is properly installed. An improperly installed hard drive could cause STOP 0x0000007B errors and other issues.
  4. Verify that the hard drive is configured properly in BIOS. The STOP 0x0000007B error could occur if the hard drive settings in BIOS are incorrect.
  5. Scan your computer for viruses. Certain viruses that infect the master boot record (MBR) or boot sector can cause STOP 0x0000007B errors.
    Important: Make sure your virus scanning software is updated and configured to scan the MBR and boot sector.
  6. Update the drivers for your hard drive controller. If the drivers to your hard drive controller are outdated, incorrect, or corrupted then the STOP 0x0000007B error will likely occur.
    Note: If the STOP 0x0000007B error occurs during the Windows setup process and you suspect that the reason is driver related, be sure to install the latest hard drive controller driver from the manufacturer for use during the installation of the operating system.
    Note: This is a likely solution if the second hexadecimal number after the STOP code is 0xC0000034.
  7. Change the SATA mode in BIOS to IDE mode. Disabling some of the advanced features of SATA drives in BIOS could stop the STOP 0x0000007B error from showing up, especially if you're seeing it in Windows XP or during a Windows XP installation.
    Note: Depending on your BIOS make and version, SATA mode may be referred to as AHCI mode and IDE mode may be referred to as either Legacy, ATA, or Compatibility Mode.
    Note: While not a common solution, you may also want to try the reverse - see if IDE mode is selected in BIOS and if so change it to AHCI, especially if you see the STOP 0x0000007B error in Windows 8, Windows 7, or Windows Vista.
  8. Run chkdsk on your hard drive. If the boot volume is corrupted, the chkdsk command might repair the corruption.
    Important: You'll likely have to run chkdsk from the Recovery Console.
    Note: This will likely be the solution if the second hexadecimal number after the STOP code is 0xC0000032.
  9. Perform an extensive test of your hard drive. If your hard drive has a physical problem, one very likely situation is the STOP 0x0000007B error you're seeing.
    Replace the hard drive if the diagnostics you complete suggest that there is a hardware problem with the drive.
  10. Run the fixmbr command to create a new master boot record. A corrupted master boot record might be causing your STOP 0x0000007B error.
    Note: This will likely be the solution if the second hexadecimal number after the STOP code is 0xC000000E.
  11. Clear the CMOS. Sometimes the STOP 0x0000007B error is caused by a BIOS memory issue. Clearing the CMOS could solve that problem.
  12. Update your BIOS. In some situations, an outdated BIOS could cause a STOP 0x0000007B error due to incompatibilities with a hard drive controller.
  13. Update the hard drive controller's firmware if possible. Just as with the BIOS in the previous step, an incompatibility could be causing the 0x7B error and a firmware update from the manufacturer may correct the problem.
  14. Repair your Windows installation. If you've just replaced the motherboard in a computer without reinstalling Windows then this will likely fix your problem.
    Note: Sometimes a Windows repair will not fix a STOP 0x0000007B error. In those cases, a clean installation of Windows should do the trick.
    If you haven't just replaced your motherboard, a Windows reinstall probably will not fix your STOP 0x7B issue.
Hope this helps,
If you need further assistance please get back in touch and i'll see what else we can do.
Thanks,
Gary
Oct 17, 2013 | Toshiba Computers & Internet
System recovry disk for gateway computer
depending on your operationg system microsoft xp does not have a downloadable disk
http://support.microsoft.com/kb/310994
How to obtain Windows XP Setup boot disks
http://freepctech.com/pc/002/files010.shtml
MicroSoft Boot Disks
MS Windows XP / 2003 / VISTA CD setup file (ISO file)
This is a special CD designed to allow you to prepare your
system for an installation of any of the above operating systems.
The disk also contains all the tools you might need to repair or access
an existing OS
. http://100-downloads.com/download.php?p=376Assembles over 100 PC hardware diagnosis tools into one bootable CD to analyze and repair hard drives and to fix boot problems (CD iso)
you will need to burn it to a disk
hope it helps
Jun 04, 2012 | Gateway CX2755 Convertible Laptop AC Power...
When i start my pc today, i had stop 0x0000007b (0xf9e48528 0xc0000034 0x00000000 0x00000000) i try with chkdsk /r end fixboot but no result.
When you start your computer, you may receive one of the following error messages:
  • STOP: 0x0000007B (parameter1, parameter2, parameter3, parameter4)
    INACCESSIBLE_BOOT_DEVICE
  • Setup has encountered a fatal error that prevents it from continuing.
    Contact your product support representative for assistance. The following status will assist them in diagnosing the problem.
    (0x4, 0x1, 0, 0)
    Setup cannot continue. Power down or reboot your computer now.
You may also receive a "Stop 0x0000007B" error message during Windows XP Setup when the Setup program restarts during the installation process. When you receive a Stop error while the Setup program is running, you receive the second error message. To troubleshoot this issue, read the following four sections to determine if any one of the issues applies to you. If none of the issues apply to you, use the following general troubleshooting steps at the end of the article. uparrow.gifBack to the top Boot-Sector Viruses You may receive a "Stop 0x0000007B" error message if your computer is infected with a boot-sector virus. If the problem is intermittent and you can start Windows, check your computer for viruses. If you find a virus, also check any floppy disks for viruses before you use them again.
For a list of antivirus software manufacturers, click the following article number to see the article in the Microsoft Knowledge Base: 49500 List of Antivirus Software Vendors Note You may have to use more than one brand of virus-detection software to detect and remove various viruses.
Important If your computer has been infected, it may be open to additional forms of attack. We recommend that you rebuild infected Internet-facing servers by following the guidelines that are published on the CERT Web site. Internet-facing servers are servers that function without a firewall or other protection. It is also a good idea to rebuild any other computers that are at risk because of their proximity to infected computers before you put them back in service.
If a virus has infected your Windows XP-based computer and a virus-detection program cannot remove the virus and repair the system, you must repartition and format your hard disk and reinstall Windows XP. For additional information about partitioning and formatting a hard disk with Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 313348 How to partition and format a hard disk in Windows XP For more information about how to help protect the boot sector from viruses in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 122221 How to protect boot sector from viruses in Windows uparrow.gifBack to the top Device Driver IssuesYou may receive a "Stop 0x0000007B" error message in the following scenarios:
  • A device driver that the computer boot controller needs is not configured to start during the startup process.
  • A device driver that the computer boot controller needs is corrupted.
  • Information in the Windows XP registry (information related to how the device drivers load during startup) is corrupted.
Windows XP requires a miniport driver to communicate with the hard disk controller that is used to start your computer. If Windows XP does not supply a device driver for your controller or if Windows XP is using a corrupted or incompatible driver, you must replace the driver with a valid copy that is compatible with your controller and Windows XP.
During the first phase of the Windows XP installation, Setup displays the following message at the bottom of the screen: Press F6 if you have to install a third-party SCSI or RAID driver. Press F6 and then follow the instructions to install a mass-storage device driver from your Original Equipment Manufacturer (OEM). For additional information about using F6 to load an OEM device driver to support, click the following article number to view the article in the Microsoft Knowledge Base: General Troubleshooting If none of the issues that have been described in this article apply to you, use the following general troubleshooting steps:
  1. If you receive one of these error messages while you are installing Windows XP, update the computer BIOS or obtain Windows XP drivers for your hard disk controller (from the manufacturer of your computer, system board, or hard disk controller), or do both. For information about how to update your computer's BIOS or obtain Windows XP drivers, contact your computer manufacturer. For additional information about the availability of drivers, see the Device Driver Issues section in this article.
    Note: If Windows NT 4.0 or Windows 2000 was installed previously on a mirrored boot partition, see the Other Issues section in this article.
  2. Use the Last Known Good Configuration feature. This may resolve the problem if you recently installed an incompatible device driver for your boot controller. For additional information about using the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 How To start your computer by using the Last Known Good Configuration feature in Windows XP
  3. Use the Repair option with Windows XP Setup. For additional information about repairing Windows XP by using the Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 315341 How to perform an in-place upgrade (reinstallation) of Windows XP
  4. Restore a registry backup. For additional information about restoring a registry backup, click the following article number to view the article in the Microsoft Knowledge Base: 307545 How to recover from a corrupted registry that prevents Windows XP from starting
May 18, 2011 | Computers & Internet
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus...
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Jun 11, 2017 | Sony VAIO VGN-NS140E/S Notebook PC
Stop 0x0000007b (0xF78A6528, 0xC0000034,
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
May 14, 2010 | Microsoft Windows XP Professional for PC
BOOTMGR is missing Ctrl + ALT + DEL I have ADVENT Notebook I have connected up A disk Drive via USB I have booted up with XP Home Edition it starts to load files then the Blue screen pops up to say that ''...
this error can come if ur pc doesnt supports windows version thats why i recommend u to change the version of windows u r installing.
if this doesnt work then mail me at aquif@in.com ,bcoz the next technique is much more advanced.
Mar 29, 2010 | Computers & Internet
Error while trying to install windows xp Stop: 0x0000007B on a dell Optiplex sx270
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
In your case though, this is most likely one of 4 capacitors that are known to blow out on any SX270. Slide the bar at the back of your PC to the remove cover side and look inside for swollen caps. Remove the fans and cpu cover as well and check around there. Replace any bad ones you can find with old caps borrowed from an old motherboard if you have one, or new ones from any decent electronics parts warehouse. This fix has worked for me on every SX270 I have ever had.
Mar 10, 2010 | Dell OptiPlex SX270 PC Desktop
Stop:0x0000007B tried to boot in all modes..we go to blue screen with stop: cannot get a command prompt either
Issue : Blue screen with Error0x0000007B
Solution
I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
The above error comes if the boot volume is corrupted and cannot be initiated by Windows XP. or You are installing Windows XP on a mirrored boot partition that was created by Microsoft Windows NT 4.0.
To completely resolve your issue i think you have to reinstall the OS.
Have to format the Hard drive
requirement
the OS - XP Home / Premium Installation CD
Disk formatting is the initial part of the process for preparing a hard disk or other storage medium for its first use. The disk formatting includes setting up an empty file system. A disk formatting may setup multiple file systems by formatting partitions for each file system.
Check this following Video Link
Help you with uninstall and reinstall the XP
Jan 03, 2010 | Dell Microsoft Windows XP Home Edition
After formatting my pc is unable to run
(1)When you power up the computer press F8 key thne if you are able to see safe mode and other menu then enter in safe mode.Then go to start menu->run type in run "chkdsk /r"
thne press "y" then scan your computer with antivirus. uninstall that antivirus because sometimes it conflict to windows.
then restart computer thne wait untill it check disk and fix errors.
Then you can see desktop screen.
(2)But if you are not able to enter in safe mode then you need windows disk or recovery disk.
Then boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set frist boot device as your cd or dvd drive.
Then save and exit settings.
Then insert disk in rom then it boot with that disk.
then follow the procedure and enter in recovery console .
Type in console prompt "chkdsk /r"
the press "y"
then it fix error on disk.
Then check in normal mode if still not load windows then follow above procedure again but this time select repair previous windows option so it repairs old windows and you get your old windows .
Let me know if you need further assistance.,
Thanks
Nov 06, 2009 | Computers & Internet
O*oooooo7b(0*f7a21524,0*c0000034,0*00000000,0*00000000)
If you can install Windows Vista and only XP not work for sure this is the solution :
SATA operation mode is AHCI
To change this :
Open BIOS
Look for SATA Operation Mode or somethin equivalent and change-it to IDE or Compatibility Mode.
Jul 19, 2009 | Compaq tc4400 Tablet PC
Computers & Internet Logo
1,783 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
