Question about Belkin (F5D7230-4) Router (587009)
I am using Belkin F5D7632ak4A. My problem is that:
I am using Belkin F5D7632ak4A. My problem is that, after I port forwarded for my BitComet and once the listen port is open, after a while, my laptop restarts. Can anyone please let me know what is the problem and solve for me. I am really irritated with the problem. I cant complete my downloads without restarting more than 10 times.
  • edwinisdenim Jul 17, 2009
    Thanks for trying. But I am not facing IP settings problem but rather after I have done port forwarding, my laptop would restart if I run my BitComet application. I'd like to know why and how to solve this.
    I know how to port forward. Thank you for helping though.
    Scholar:
  • 55 Answers
In doing a port forwarding, you actually need to assign a manual address on the computer where you are using the service port for the computer not to change the IP address. If your private address on the network is 192.168.1.XX then you may assign on your computer 192.168.1.2-99 any of the address there. Also you may need to know the DNS you are using on the router which you can find on the status tab of the router.
To assign an IP address, if your computer is wired then right click on the wireless connection and select properties, if it is a wireless computer right click on the wireless connection and select properties.
After you have selected the said properties> look for Internet Protocol TCP/IP then select properties.
Then click on USE THE FOLLOWING IP ADDRESS and USE THE FOLLOWING DNS server as well.
then from there you can put in the set of address you have for ex.
IP address 192.168.1.10
subnet mask 255.255.255.0
Default gateway 192.168.1.1
DNS
preferred DNS 66.28.87.105
alternate DNS 66.28.87.104
Note: these are just example. after you have done assigning an IP address then you may do the port forwarding again. change the IP address on the port forwarding tab to the IP address you have assigned. Then don't forget to save the settings.
Posted on Jul 17, 2009
Bitcomet listen port is blocked
You need to forward the specific port bit comet uses to listen,in your
router.To do this follow the below steps.
1) Go to this page http://portforward.com/
2) Scroll down the page and search for your modem/Router and
click on it.
3) Select the aplication from the list,in this case Bitcomet.
4) Now follow the step-by-step guide on this page to successfully forward your bit comet port.
Once you have done that restart your bitcomet and the listen port should now turn green indicating that it is open and functioning properly.Hope it helped.
Nov 21, 2010 | BitComet
Forwarding ports
Port Forwarding is explained indeepth by the torrent companies help FAQs section,
Heres a link that may helps you too....
http://www.fixya.com/support/r4582466-set_up_speed_touch_5x6v6_broadband_modem
In the Admin function you can accept the ports if you have the correct servers address's
You must add them to your firewalls permission settings and then try the test again,
Note ,
Even with Port Forwarding set up,
you will also require the correct band width and downloader from the torrent site,
ie,
Bit Comet and Bitcomet Excelerator
The downloader and the high speed function,together.
Hope this helps,Misterdj
May 03, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How to forward website to belkin n1 vision router
You would have to log into the router to configure port forwarding on port 80. You would have to know the IP address of the computer hosting the website and put that in the routers config under port forwarding.
Oct 27, 2009 | Belkin N1 Vision Router
Listen Port of TCP: 2869 (Blocked by Firewall/Router) how do i change nat router settings?im blocked when usin bitcomet software
try to disable ur firewall setting, enable nat, and rip
try set port forwarding to port 65535, dont forget to set bitcomet port 65535 too
Oct 08, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Need a port opened to speed up downloads
Hi. It really depends on what type of modem or router you are using to open up ports. Also if you are using an application for downloading such as Bitcomet, you need to find out what port or listening port is currently configured on Bitcomet. for example, the listening port on Bitcomet is 4545, then you have to open port 4545 on your router or modem.
You also need to make sure that your modem or router has port forwarding features..
you may also visit this link for instructions on how to forward or open ports to different types of routers...
May 10, 2009 | Computers & Internet
Bitcomet and Belkin router
To fix this issue all you have to do is,You should open the bitcomet downloader portnumbers on the belkin router,you need to open default page by typing 192.168.2.1 in address bar.
And also i would like suggest you to disable firewall on router and check for firmware update... It may be quiet difficult for you to do all this.please call tollfree number"belkin" and ask them to change these settings which i have mentioned.and it will definitely work.....
.....Hope this is help full for you
Apr 14, 2009 | Belkin (F5D7230-4) Router (587009)
Yellow light with bitcomet 1.10 using xp and netgear dg834g
go to your router setting and try to disable all firewall, if still not work, check your port forwarding setting, it could went wrong, different router have different name for port forward. must set bitcoment port ..let say 65535 and set port in router 65535.
Mar 28, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Listenning port bit comet
BitComet requires you to be able to receive incoming connections. If you're behind a NAT router but don't have port forwarding configured properly, incoming connections will be stopped by your router (won't get to your computer).You need to configure port forwarding, so your router knows that the incoming connections are for BitComet and will be allowed through (= forwarded) to your computer.
There are several versions of your router:
DSL-2640B, DSL-2640Bv2,...
Go here, scroll (almost all the way down) and find your router model.
On the next page, skip the advertisement (upper right corner) and look for BitComet.
Simply follow the instructions on that page - they are precise and correct.
In general: You can use ANY port, but I would prefer a listen port between 49152 and 65534 because they're classed as "Dynamic and/or Private Ports" by IANA, so nothing else should be using them by default and they're not the standard ones blocked by ISP's or trackers, but - as I said - you can enter any other port you wish.
If you have any more questions, just come back and let me know - I'm happy to help.
Good luck & thanks for rating!
Mar 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Cant get a green light in bitcomet
You might follow these instructions
http://portforward.com/english/routers/port_forwarding/Belkin/F5D9230-4/BitComet.htm
(although the creation of a static IP is not necessary) if you don't make it then you might have to change the IP you forward the port to depending on whether your computer's IP changes. (you can check that under the network page you find in control panel by highlighting the network you're connected to and looking in the bottom right corner of the window) (or by opening cmd through run and typing ipconfig).
Oct 13, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
PORT FORWARDING
you can check a site for speed site to help. http://www.speedtest.net/
last option call the survive provider
Aug 13, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7230-4) Router (587009) Logo
367 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
