Question about Mitsubishi VS-45603 45" Rear Projection Television
Mitsubishi vs-45603 How do I know if this tv is ready for the switch over in 2009?? Analog or digital... Am I going to have to buy a new tv???? How do I know if it is HD ready???
  • 192 Answers
This set is not HD capable.
When all signals are supposed to go to High Def., there is supposed to be a box that will convert the signal from 1080i to 480i.
I'm not sure how it will look, but, the down converted signal seems to look good for now.
The new technology is coming down in price and the new features are coming at us at record speed.
For instance:
The new tuners are capable of receiving local high definition stations using rabbit ears.
You don't need a cable box to receive all stations (except premium stations such as HBO) including High Definition if the turner has a "Clear QAM" tuner.
LEDs being used in LCD and DLP make them less vulnerable to loss of lamps prematurely and a heartier set.
LCDs and DLPs are becoming the set of choice due to contrast ratios as high as 100,000 to one and unlimited color.
A new type of set is just around the corner using laser technology (from what I have been told by manugactures).
In conclusion:
Your set is not HD, but, it should still operate when or if the change does take place. You may need to get more equipment to help with this change and it may cost more than buying a new set.
Posted on Nov 18, 2007
    Problem Solver:
  • 9 Answers
MITSUBISHI VS 45603- 46"MANUFACTURED NOV 1998---Tv works great until we moved it from one side of the room to the other.. now, ill plug it in, turn it on, the power light pops on then it shuts itself off........ no matter if i have it plugged into an extension cord or straight to the wall,,, what is the problem???
Posted on Jul 10, 2011
The TV says volume off how do I turn it back on?????
Go into the main menu and look to see if the SPEAKERS are switched off--the model listed is rather old and may also have a internal/external slide switch on the rear of the set.
Apr 24, 2012 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-45603
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no..
Good luck..
Sep 17, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
My tv is locked and i do not know the code
Devices: Mitsubishi VS-45603 45 in. Rear Projection TV (only)
I'm hoping your have a working original remote for this creature from 1998 (the dark ages of Analog).
The first thing to try to reset a stored "lock code" is to unplug the set and leave it unplugged until the code is lost (or reset to the default). How long will this be? Mitsubishi won't tell (see below).
Service Codes are for the use of qualified service technicians only. Damage resulting from the unauthorized use of Service Codes will not be covered under warranty.
Manufacturer: Mitsubishi
Model: VS-45603
TV type: Analog Rear Projection Television
Chassis: VZ5
Year of Manufacture: 1998
Option Menu Code: 1370
Circuit Adjust Code: 2357
Convergence Adjust Code: 2359<4><5><6>
Since Mitsubishi fails to provide online support for its own products (even Users Manuals are unavailable), its left to the consumer to discover how to use & maintain Mitsubishi Electronics Products. Accordingly, I've no way to provide guidance on how to use the above Service Codes, nor is assistance possible if something goes horribly awry during the course of experimenting with them.
Please post your results.
Dec 05, 2011 | Mitsubishi VS-45603 45" Rear Projection...
After big storm the tv only shows small picture in upper right corner. Will not allow to go to full screen. VS-45603
You are in pip mode, and if itwill not let show on regular mode, then your tuner is out,and youcan bypass it and go directly into the video input with RCA cables from your recieever,and put your set in video mode,better picture, and save you 500 dollars on a new tuner.
Jul 07, 2011 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-45603 had power outage and when it came back on it says TV is locked. How do I unlock it?
Go into the 'Menu' -> then 'Setup' -> then 'A/V Connections'.
You should see an option called 'Locked to Input' switch it to 'No' and your problem should be solved!
May 05, 2011 | Mitsubishi VS-45603 45" Rear Projection...
Sound is distorted on this Mitsubishi Model No. vs-45603
how old is your unit?sometimes distortion is caused by interference,like motor or automobiles but that is minimal.connection of the antenna , cable and other connectors can also be the caused.if all these are not the cause, call a tech.the audio circuit is faulty.
May 14, 2009 | Mitsubishi VS-45603 45" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Televison & Video Logo
356 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
