Question about Toro Lawn Mower With Toro Power Tools
No torque/hp when cutting a patch of grass.
My problem started when my 6.5hp Tecumseh engine would die after running for about 7-10 seconds. I removed the carburetor, and cleaned it with brake-cleaner and compressed air. After I placed the carburetor back unto the engine, some improvement was immediately noticed. The engine would no longer stall, and continue running but the rpm's was very low. I turned a set-strew that is located on the carburetor clock-wise, until I reached a desired rpm, and everything had appeared to be OK. But, when I went to use the mower, and would hit a patch of grass, the mower wanted to stall, and acted as if it don't much torque/hp. The engine seeems weak when put to the task, and acted like a 2.5hp or 3hp engine. I called a couple of Toro repair shops here in the area, and had one of the repair shops to suggest that I had/have contaminated fuel, or bad piston rings, but the engine doesn't smoke...just a little when I first start the engine. I had the other repair shop to suggest that the problem could be with the governor; that theory I'm more inclined to agree with. Do you have any suggestions, as to what my problem may be???
JK Lewis
Orlando, Fla.
    Sniper:
  • 53 Answers
SOUND LIKE THE NEEDLE OR FLOAT IS BAD IN THE CARB. I SUGGEST GETTING CARB REBUILD IT DOES COST THAt MUCH.
Posted on Jul 17, 2009
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
5 hp tecumseh no power
you need to remove carb for cleaning... if it has an adjustment on the bottom of carb try turning it SLOWLY in and out... also possibly a screw on the side under a black cap... might try it as well engine model number would help here
Dec 11, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
Mower starts and runs for 10 - 15 seconds, then dies. Will almost start again, but soon will not even kick over. After a while, it will start for a few seconds. This is a 15 horse Tecumseh that looks...
It sounds like a carburetor issue. The jets are probably gummed up from the old gas that was in it. Remove the carburetor and clean it out with a can of carb cleaner. Then reinstall.
May 22, 2011 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Jul 20, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
My lawnmower engine cuts out
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Apr 12, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
320 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
