Question about Fantom Vacums Lighting Canister Vacuum
Powerhead for Phantom Lightning - I need one too!
The tube part between the powerhead and wand broke.
  • sharonben Jul 17, 2009
    I spoke with somebody from Euro Pro who bought Fantom when they went bankrupt. They said they don't ahve those parts and I won't be able to get it repaired. I'm going to take it in to a repair place here and see what they can do.
  • Anonymous Mar 14, 2014
    Have to keep shaking it to make it run
    Where do I buy a new power head wand and hose?
  • 4 Answers
Too bad sam16_m couldn't actually share the phone number for the Customer Care that can supposedly sell (also not confirmed)the part needed. Not an expert if you can't solve the problem.
Posted on Oct 25, 2009
    Scholar:
  • 78 Answers
U'll definity get a new one for it, no worries just call the customer care, they will provide u with the new one, cost some 2-5$ .. thank u
Posted on Jul 17, 2009
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting evacuumstore.com
Nov 17, 2013 | Vacuums
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
The powerhead cuts in and out on power as you vacuum with the brushes. Works ok with suction only. Have replaced both wands and still cuts out, Can it be the powerhead connections? Help? TJZ
had the same problem with mine check all the prongs on the 2 wands and on the power nozzle and on the handle itself you will probably see that one of them is discolored or burned looking you will need to replace that section, I had to replace one of my wands, and then a second time I had to replace the hose section with the handle attached.
Oct 04, 2009 | Eureka 6984A Bagged Canister Vacuum
Need new powerhead for Fantom Lightning Style PH1A - Where can I buy it and how much?
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested.
Jul 15, 2009 | Fantom Vacums Lighting Canister Vacuum
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Powerhead does not work and the light doesn't work. Canister does work
Some of these has a reset button to push on the powerhead. Check the plug at the end of the hose handle, is it pushed in, if you push on it and it goes further in, then the tube in the handle will have to be replaced, the holding tab broke off of the tube. Pull the wand off and look at the prongs to see if they are burnt. it they are, then that power cord will have to replace as well as the want.
Jan 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Loose Wand Connection
its just worn, sometimes getting a new lower wand can fix this
Jan 18, 2008 | Vacuums
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Fantom Vacums Lighting Canister Vacuum Logo
228 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
