Question about Datacard SP35 Printer
Does anyone know of a roller repair kit for SP35. the rollers are hard and will not grip the card, to drive them thru the printer. they get half way thur and jam
    Problem Solver:
  • 9 Answers
A good clean using the cleaning cards should help.
how far does the card get into the printer?
Does it pick a card from the hopper OK?
You can replace the top rollers easily yourself, but the others would need to be done by an authorised reseller
Posted on Aug 05, 2009
My datacard sp 35 does not pick cards from the hopper easily i have to give it a little push.how can i solve this?
The rubber roller that is in the hopper (pick roller) needs to be replaced. Most likely all rollers in the printer need to be replaced. Contact TulsaBiz.net or MIdWestIDSolutions.com You can buy parts from them or send in for repair.
Jul 07, 2011 | Datacard SP35 Printer
Hello Sir, Please help me, i hav 6690cw printer, when i am printing multi copy (50copy) after 1 or two copy, there is a paper jam indication, half of the paper is in tray, sometimes little end is there in...
Your roller(s) are worn and failing to properly grip the paper to feed it.
The printer technician's solution to this problem is to order a "Roller Kit" for the printer,
and replace all the rollers - when one starts to lose its grip, they all will soon go - since
all wear at about the same rate.
This happens after a printer has printed alot of pages - the definition of "alot" varies from
printer to printer.
Feb 13, 2011 | Brother MFC 6490CW InkJet Printer
Datacard sp35 - cleaned it several times, First it will tell me the card is lost, we fish the card out, next it will tell me that the printer ribbon is broken. it is not broken, we have wasted so much...
Sounds like the rollers are going bad. From time to time the rollers on this device can definitely go bad. That's the reason you have to keep fishing for your cards. Try replacing the rollers on the device.
It may require some technical knowledge.
Please feel free to ask any further questions.
Dec 16, 2010 | Datacard SP35 Printer
Paper feeder does not appeat to be able to 'grab' paper ?? what can i do
Please refer to the manual and then open the ADF clean the rollers and then try again some times due to dust in the rollers then paper is not feeded.
Apr 11, 2010 | HP LaserJet 2420 Printer
Cards not feeding through on SP35
You will need to replace the Pick Roller (the first roller you see from the card hopper.
You most probably have a smooth roller and the new type are ribbed. The printer has to be dismantled to replace the roller. Suggest you contact your local reseller.
Jun 24, 2009 | Datacard SP35 Printer
My old laserjet 4+ has become tired and I have to pull the paper out manually. I plugged in another similar machine but this one will only print the first page continuously under DOS and will not stop. It...
The Laserjet 4+ that you have to pull the paper out needs a preventative maintenance roller kit. The rubber output rollers get hard and will not grab the paper and advance it thru the printer. The kits include all of the pickup rollers and the output rollers. We sell the kits for $25.00 plus shipping and it includes a copy of the service manual.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jun 23, 2009 | HP LaserJet 4 plus Printer
Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Mar 27, 2009 | Datacard SP35 Printer
Card jam
You have to change the roller just inside the picker roller.
Sometimes the glue that holds the "cleanig roller" loosen from the pin.
Sorry, bad english... :D
Jan 30, 2009 | Datacard SP35 Printer
Datacard SP35 + giving broken ribbon error
You have to clean the roller under the printerhead.
The big black one..
I suggest you install Diagnostics.
Go to motor test, and take the transport fast reverse. 300 sec.
Now you can clean the roller easy.
Nov 25, 2008 | Datacard SP35 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
Datacard SP35 Printer Logo
211 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
