How to take the back off the TV?
I have a big Sony that blinks 6 times..etc. I've been on enough forums to see that I can remove the D board...bla bla bla.......& there are several options for repair (send it off...or buy IC's off of ebay and fix myself.... I'm an engineer and can fix about anything).
I'm would like to start off right and don't see an obvious way to get the back off the TV except to start removing all the screws, etc.
How should this be done...should I lay the TV forward on it's screen?
Any advice would be helpful.
Yes you can take the back off and could probably do your tv a favour by blowing(carefully) the two inch layer of dust that sony tv's tend to gather,(if done regularly, it would stop these problems from happening in the first place)..... dont take the back off till you have allowed a 12 hour discharge period(thats unplugged) and if your an engineer then you can follow the screws that apply to the back and go over the top of the inlets.... then just tilt it forward when your ready to pull it off..... happy fixing....
Posted on Sep 22, 2008
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Will only turn on for about 3 second with no picture and then turns off. Standby light blinks 6 times
For the KV30HS420, 6 blinks, pause, 6 blinks, etc. means "LOW +B OCP/OVP (overcurrent/overvoltage)" and the probable cause locations listed are as follows:
1. +5 line is overloaded (A, B, M boards)
2. +5 line is shorted (A, B, M boards)
3. IC504 is faulty (A board)
hope this helps John
Jan 11, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony Trinitron TV
read the answer on this page really helpfull
Apr 01, 2010 | Sony FD Trinitron WEGA KV-27FV17 27" TV
Light blinks 6 times, no picture, no sound
6 times blinks shows error of Low +B, OVP/ OCP
Replace IC6501 & IC8002 [ MCZ3001D ] on D board.
If you are handy with electronics stuff repair and can solder parts in circuit board then replace above said ICs or call local TV tech to do the job.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I originally had a convergence problem, and through research on forums and the service manual I removed and replaced the two IC's and one fuse on the ''D'' Board. I put the card back in and made sure...
if this set has a small power board called the "G" board triple check a couple of small pico fuses generally they are 5 amps in value, most of the time you will see them start with a PS also lets not forget the small pico fuses that go bad around the convergence IC's also they start with PS generality there are 6 of those on the convergence board their value is 3.15 amp.I(we) will need you model number for the set!!! Good Luck if you need further assistance you can find a complete kit of convergence part kits onlinr for you tv repair try google or look up tvrepairkits as most of the time they have takebn out the complication of knowing what you will need to complete your TC repair yourself
Larry Dillon (AKA Techman)
Sep 01, 2009 | Sony KP-51WS510 51" Rear Projection...
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) six (6) times then there is a two seconds break followed by another six flashes...
6 times blink shows problem with back light inverter board.
TV requires back light inverter board replacement. If you have electronics repair experience and want to repair TV by yourself, let me know to guide you part purchase.
Apr 13, 2009 | Sony KV-35S42 35" TV
Sony FD Trinitron WEGA KV-34HS510 ... does not power up.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.This may help the solution or let no what is wrong!!
  • Jan 16, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    Televison & Video Logo
    90 people viewed this question
    Top Televison & Video Experts
