Question about Sony Cyber-shot DSC-W70 Digital Camera
Lens will not open when power on.
When I power on my lens does not open as it should. The screen remains black with a message telling me to "Turn the power off and on again."
And so I do, but that does not fix the problem.
When I power on it makes the noise as if the lens is opening, but never does.
  • 300 Answers
Hi!
The lens are broken or got some sand or something inside so the lens cannot come out. Contact your local Sony service center. If they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in a Sony service center.
Tom
Posted on Jul 29, 2009
Dsc-P52 lens cover sticking
You need to go in and physically open the lens cover.
1. take out batteries 2. remove memory card + the small phillips screw.
3. remove the 3 remaining exterior screws. carefully with a small flat tip screwdriver pry the plastic halves slowly. eventually they will come apart. 4. at the bottom remove the small ribbon cable. 5. disconnect the mini motor wire, black and red. 6. unscrew the motor drive for the lens cover and then open the lens. 7. purchase a new lens cover motor. 8. If your screen still says turn off , then press menu and delete some files. good luck ! Work Slowly and carefully and ground your hands to a pipe somewhere before working on the unit. the static electricity could ruin the circuits !
Feb 24, 2012 | Sony Cyber-Shot DSC-P52 Digital Camera
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
The camcorder is on and the lens cap is removed there is still a message on the screen telling me to remove the lens cap. The screen remains black and only the words are visible
I have a JVC camcorder and have had it fixed 3 times for the same problem, I would suggest setting it up for service. I am glad I bought the extra warranty with mine.
Jan 04, 2010 | JVC GR-D22U Camcorder
When turn on tells me to remove lens cap , no pic
CCD (imaging IC ) went bad and require replacement.
Nov 15, 2009 | JVC GR-D22U Camcorder
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Lens will not open
whille turning cuyber-shot ON, tapp the camera with other hand. if you put the lens side downward, this trick will work.
May 28, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Lens error
i had this problem i turn my camera on the lens came out i turned them then my camera stop sayind lens error but now my pic is not clear
Jan 06, 2008 | Nikon COOLPIX L4 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Lens won't retract : /
Another common problem. Lens troubles. You have either knocked your lens out of alignment or you have a foreign body jamming up the works in the lens control unit. There have been many so called fixes for these problems but usually end up causing more problems than curing. You could check that you have fully charged new batteries. Some cameras need that extra kick to get them to open the lens fully. Worn out batteries can stop a sticky lens in it's tracks and tell the processor there is a problem and to close down. It's well worth trying before writing it off.
Jul 06, 2006 | Panasonic Lumix DMC-FX8 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
236 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
