You probably have a ice dam in your ice tray. The anger is trying to dispense if but if the cubes have frozen together and produced a large chunk of ice it cannot break up. Open the freezer door completely and lift up and pull out through ice tray. Remove ice until dam removed. Reassert tray and make sure to turn ice maker back on. It is essy to inadvertently bump switch. Try dispensing ice to see. If noise went away.
Hope this helped!
SOURCE: Humming in Whirlpool Side by Side Refrigerator
It is probably just your water inlet solenoid being activated. Not to be concerned.
SOURCE: GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
