I have 64mb RAM installed on my amity cn2 computer - 32 base and 32 upgrade from previous owner. Would it make a difference to remove the 32 and put a 64 in for 96 (max supported)? And if so, where is the memory compartment? I can't find it.
  • listferg Jul 17, 2009
    i don't know how to open up the computer. Do I just start undoing screws on the back?
    President:
  • 828 Answers
It is all inside the CPU, you can see the memory module in the motherboard... its very easy to find in it because if you have 64MB right now, they were the same object or pieces...
Posted on Jul 17, 2009
Can i run windows 8.1 64mb if i have 32bit operating system installed ram 8gb with 2.97 usage x64-based prossesr
You would have to install Win 8.1 64 bit from scratch; new copy with new license. Then you'll have to reinstall all of your old 32 bit programs, some may not work on 64 bits.
Feb 10, 2015 | Games Video Game Consoles & Games
Tip
IF you just installed a new video card is your computer slow
Yes more often then not anyone who has just got a new video card installed computer will slow down. The culprit is the 32 bit based operating system. The more grafix your computer manages the more ram it will consume.
THE 2 BEST SOLUTIONS ARE
GET MORE RAM OR UPGRADE TO A 64 BIT OS Like windows 7
on Apr 22, 2010 | Computers & Internet
How to add ram
open the panned which is located on the base of the laptop and just buy a ram use the model number listed in the catalog or you also check from toshiba website using the model number of your laptop.
there will be two slots in the laptop one which will have a RAM on it and the you will see the other slot which is empty so you just need to insert the RAM like the way previous ram is attached on it. and thats it you can turn on your lappy and u r good to go
Jul 24, 2014 | Toshiba Satellite Computers & Internet
I have a compaq presario 5000 desktop and it supose to have a maximun of 728mb of memory cuz i upgrade it originaly it had 64mb all the card has the same speed 100mhz it runs them but when u chek on my...
to see how much memory you have on it ..just click on my computer right ..and select properties..It will display the CPU and the ram memory on the bottom of the window..If it is less than the one you know you installed ..and the difference is more than 32 or 64 M ..(it may be this difference cause the video card may use them and will not appear as usable for the OS ) If it is larger ..than that ..open it up and check the modules to be plugged correctly ..and even remove the bios battery to force the board to see all the memory ..Another thing you can do is to reinstall the operation system and force to see the memory ..In case you never done it when you upgraded ..( i think this is the case ...old computers always needed the reinstalling for to recognize ram on upgrade )
Aug 16, 2011 | Compaq Presario 5000 PC Desktop
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
Memory (Upgrade-Max) how I buy for the ASUS L 7200?
You could have tried GOOGLE.
Your computer has 64mb ram built in and can take a maximum of 320mb. You have 1 slot to add memory too
You can add 256MB, 144-pin SODIMM, SDRAM, PC133
Jul 26, 2010 | ASUS L 7200 Notebook
Beeping on start up
Your motherboard has 64Mb built-in RAM and the video card needs some video RAM and has grabbed 8Mb of RAM which leaves the system with 56Mb of RAM. When you insert a 64Mb RAM module you have a total of 128Mb of which the video has grabbed 8Mb which leaves the system with 120Mb.
You can't change stop the video card from grabbing 8Mb of RAM, the RAM is essential for the video to work.
You can upgrade the RAM by removing the 64Mb RAM module and insert a 128Mb or 256Mb RAM module. You may even be able to insert a 512Mb RAM module if the motherboard will accept it, you need to check the specification of your laptop to see the maximum amount of RAM the laptop can handle.
May 21, 2009 | Compaq Evo Notebook N150 Notebook
NOT ENOUGH VIDEO MEMORY - video ram required 64mb
You need to upgrade your video card to one with the required ram. What OS are you running?
Apr 04, 2009 | Adobe Photoshop 7.0 for PC
PC RAM
This refers to the data width and chip configuration. 64*8 is an 8 chip 512MB module. (8 components @ 64MB each) 32*8 is an 8-chip 256MB module. (8 components @ 32MB each), etc.
Mar 03, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
Computers & Internet Logo
David Payne
David Payne
