I have a Frigidaire electric range model FEF367CASA. The problem is the oven. No matter what temperature I set the oven at, it doesn't shut off. It keeps heating well over 550 degrees and doesn't turn off until I hit cancel. I also don't get any error codes on the display.
My Frigidaire smooth top convection oven started beeping and showing "F1" on the display....
(More)
My Frigidaire smooth top convection oven started beeping and showing "F1" on the display. Oven door lock keeps opening then locking then beeping. All functions are non operative. What do I do? Ove is only 3-4 years old.
My frigidaire stovetop blew a fuse and it now will not turn on. The display says F1 and beeps. I...
(More)
My frigidaire stovetop blew a fuse and it now will not turn on. The display says F1 and beeps. I unplugged the unit at the wall twice for 30 seconds, but it still is not working.
I have a TAPPAN oven, the bottom element does not work. I think I need to replace it. The...
(More)
I have a TAPPAN oven, the bottom element does not work. I think I need to replace it. The model#MEF303PGWC serial#VFO1539095 How do i do this, can you send me a diagram and instructions. Do you know where i can purchase the element, I live in Amsterdam N.Y. Could it be something else that causes the element not to work? Thank you
saludos... soy tecnico en electronica pero me trajeron una fuente de un refrigeradorcito. el...
(More)
saludos... soy tecnico en electronica pero me trajeron una fuente de un refrigeradorcito. el refrigerados solo hace oscilaciones y se baja el voltaje de la fuente principal de 12volt por lo que no giran los ventiladores, el circuito fue cambiado trae tl494 no estoy seguro si es original. mi correo es moises2007@latinmail.com agradesco su atencion y espero su respuesta
My frigidaire range gives off a F1 signal for time to time. This began last week and continues...
(More)
My frigidaire range gives off a F1 signal for time to time. This began last week and continues peroidically when using the burners and or oven. Is this a problem with the sensor?
