Question about Remington HC-600 Hair Trimmer
Blades pull hair when cutting
Hello, I have a Remington hair trimmer which worked perfectly...until I took the blades off to clean the hair trimmings out of the trimmer. I put it back together, but, now it pulls hair instead of cutting smoothly. Does it need to be calibrated by a professional? If yes, is there a service shop in Portland, OR, or should I send it somewhere?
  • Anonymous Mar 30, 2014
    blade pulls hair
    Problem Solver:
  • 12 Answers
Just make sure the blades are aligned precisely and make sure it is well oiled. It should be oiled after every use. I use WD40
Posted on Aug 11, 2009
  •  Mannys Sharpening
    Mannys Sharpening May 27, 2012
    Using WD40 is too light of a oil plus WD40 is like a solvent, this actually dull the blade, Clipper oil is recommended for any hair clipper it stay on the blade longer and has a better lubrication.
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
What may be cause for trimmer's unusual noise?
Have you lubricated the blades? You can buy spray lube (Remington Shaver Saver) for this purpose.
Feb 11, 2015 | Remington HC-921 Hair Trimmer
Remington MB-70 mustache and beard trimmer is very loud. Is there any way to adjust it?
That is why it was so cheap. It will always be noisy, but you may try cleaning if with the brush after every shave.
Nov 10, 2017 | Health & Beauty
Trimmer not cutting as well as it use to. Do I
hello. Both of your solutions will give you what you need which is a trimmer that cuts well. Here is the link to remington where you can price each choice. Joe http://www.remington-store.com/category.asp?CAT=parts
Mar 29, 2010 | Remington Precision HC-8017 Hair Trimmer
Trimmer not working
the trimmer may be jammed with hair particles. clean the trimmer blades really good with an old toothbrush dipped in rubbing alcohol. you can also turn it on with the tip of the trimmer blade dipped in a shallow container of alcohol.
if your trimmer blade is sufficiently clean and still doesnt work, the rocker arm that moves the blade must be broken. Remington does not offer replacements for the trimmer part
Jan 16, 2010 | Remington Microflex R-842 Electric Shaver
Blades do not cut on the remington hc8017 trimmer they just pull the hair
Try cleaning the blades as they maybe clogged with hair.
Oil them regularly to prevent seizing.
Jun 18, 2009 | Remington Health & Beauty
Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Apr 11, 2009 | Remington Health & Beauty
Remington HC-921 Mens Clipper Kit Pulling hair not cutting
no but I can't wait until someone does- having same problem. They worked fine then didn't
Mar 29, 2009 | Remington Health & Beauty
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Remington HC-600 Hair Trimmer Logo
1,389 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
