Question about AOC LM729 17" LCD Monitor
Monitor menu problems
My i have aoc monitor i used it for a year now...
but now the menu display keeps on appearing without touching it...even
i touch the exit it appear again..can you help me?
  • anderkober Dec 10, 2007
    same thing happens to my crt monitor, the menu keeps on reappearing by itself. its so annoying.
    An user who is expert in 3 categories / brands.
  • AOC Master
  • 848 Answers
Monitor menu problems? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From can find those parts
if you have any question,please let us know,we sincerely hope we can help you!
you can also check this boards whether suit you:
715L1103 AOC IDPC7425A3 Power Supply for TFT1780PSA LM729
Posted on Dec 23, 2014
    Problem Solver:
  • 10 Answers
Hai Ejor,
You need to replace the front panel menu buttons,
Posted on Dec 22, 2007
I have AOC e943Fwsk monitor. I can't turn it off with power button. what should I do now?
Unplug it and hold the off -on button in for about 30 seconds then plug it in and see if it works.
Sep 20, 2014 | AOC E943fwsk 18.5" Led Lcd Monitor - 5 Ms
AOC monitor says OSD locked
OSD means on-screen display. As you make adjustments, they are displayed on the screen. You may have to press the OSD button to unlock it.
Sep 06, 2012 | AOC V22 22" Monitor
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
How do u get to the menu on my aoc lcd monitor
Depending on the brand and model of your monitor, there may be extra features that require special troubleshooting tips, or there may even be alternate ways of troubleshooting basic problems. For this reason, it is important to keep your user manual.
If you have come across an issue with your LCD monitor that cannot be corrected through the basic settings, you should consult the user manual to determine troubleshooting solutions for your specific monitor.
For example, The AOC 175F LCD monitor features a 90-degree rotating display, which, in order to rotate correctly within Windows XP, must have AOC's third-party software installed. This is not something required of all LCD monitors, as not all LCD monitors offer a rotating display.
If the troubleshooting section of your user manual still does not solve the problem, it may be necessary to contact the manufacturer's support team (via phone or web) to discuss what is wrong with your monitor
Jun 26, 2010 | AOC LM729 17" LCD Monitor
The monitor keeps displaying the menu box randomly in the centre of the screen and I can't stop it from appearing. Can anyone help please?
10% chance it is the button of the menu stitch. Can you tap the monitor on the front, sides or corners without moving it or the cable and make it go into Menu?
80% I'm guessing you have a broken but occasionally touching connection wire in the video cable. Take it off (both ends) and go to Micro Center or PC World and get a replacement. This is an odd problem...
10% chance it is the button of the menu stitch. Can tou tap the monitor and make it go into Menu?
Mar 26, 2009 | Hansol H750 17" LCD Monitor
Westinghouse L1916HW Monitor On-Screen Display keys malfunction
Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms Widescreen Monitor and it turns itself off . Sometimes it works without problem for long time or just for 15 mins, and after turn on it several times the problem disappears. Now,when it is working without the problem, sometimes the volume menu appear on the screen without touch the monitor and if you try to close it, appear again.. I am using it with Windows 7. I need help. Now, I have a router wireless close to it, Can it affect the monitor?
Dec 14, 2008 | Computers & Internet
Problem in monitor
1. First cheak the control panel microswitches. if any dry points on the panel ,solder the drypoints.
2. Replaced the microswitches
3. Cheak Control Proccer input voltage DC 5 V, from power section.
4. Changed the 7805 Reguletor. ( near to Control Procer )
Oct 03, 2008 | AOC LM729 17" LCD Monitor
AOC 17" Flat CRT Monitor
Could be problem of key switches!
Try replacing or check for leakage,high resistance across switches using ohmmeter.
Jul 26, 2008 | AOC CT720G 17" CRT Monitor
AOC spectrum 7 Glr ?
Initially, I would suggest that you do a full reset, that is unplug the monitor from the mains and the PC for a couple of hours (preferably overnight). The idea is that the monitor will reset itself to default factory settings. Thereafter try again.
Should problem persist, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 12, 2008 | AOC LM729 17" LCD Monitor
AOC LM729 17" LCD Monitor Logo
354 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
