Question about Exercise & Fitness
I need the wiring diagram of my Proform 540 s treadmil and cannot find one anyplace. Help.
  • jkzrieger Aug 02, 2009
    Still need wiring diagram.
    Thank you, unfortunately there is no wiring diagram anywhere on the unit, motor hood has been off, no technical sheet. what next do you suggest?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Under the motor hood there should be a technical sheet .It is in a plastic envelope glued to the insde top of the motor hood.I think there are 4 screws to remove the hood.
Posted on Aug 01, 2009
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
Speed and incline button not working
Please RUN the software calibration for diagnose, troubleshooting and fix it. However see the diagram attached, and lube the gear, shaft too.
God bless you
Jul 12, 2012 | Treadmill Doctor PROFORM 540 TREADMILL...
Proform crosswalk 397 will not incline
see the diagram, and RUN the software calibration for diagnose and troubleshooting.
lube the gear and racking from elevation motor, clean, and tigh any wires connectors:
Jun 29, 2012 | Proform Crosswalk 397 Treadmill
Proform 540 treadmill stopped working
1) Lube the deck belt, this is problem by possible deck worn.
by that reason produce enough friction, causing to the electronic system shut down for protect.
2) Lube the rollers bearing
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) Try to RUN the sofware calibration for diagnose and troubleshootign
God bless you, See the block diagram
Jun 13, 2012 | Proform Exercise & Fitness
Treadmill starts at 2 mph runs for a second then shuts off
1)The walk belt lift 3-4"aprox, you must adjust the tension.
2) Read your user manual and proceed as indicated.Tense the drive belt.
3) if the problem persist you will have electronic+ electric problem with the main motor controller board + motor . Test it
sincerely.
Dec 13, 2011 | Treadmill Doctor PROFORM 540 TREADMILL...
Proform 540 console doesn't work
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill andremove the motor hood cover. The reed switch is mounted on the frame next tothe front roller pulley. There is a magnet glued into the front roller pulley.When adjusting the reed switch, make sure it is pointing directly at themagnet. Move the tip of the reed switch within 1/8" of the magnet. Also,check to see that the wire is not damaged, and is connected to the console. clip_image002.jpgOptic Sensor: Unplug the treadmill and remove the motor hood cover. The optic diskand sensor are located either at the end of the motor or the right hand side ofthe front roller. The optic disk spins between two sensors on the optic switch.The disk must spin freely without touching either sensor. The sensors can bemoved by loosening the adjustment bolt holding the switch to its bracket. Theswitch can then be slid. Center the disk.
After you did these adjustments: Please tight the keypanel flexible cable vs display board and then tight the connector from display board vs lower board.
Try to clean the keypanel with spray contact cleaner with carefully and patience.
See diagrams. Good luck, sincerely. G-d bless you.
12_6_2011_5_46_41_pm.gif12_6_2011_5_46_57_pm.gifWith the block diagram that I did you will have a strong resultant if the keypanel board is faulty or display board completely. See how the main motor control has 90% functions in any treadmills.
E.CUADRA
MANAGUA, NICARAGUA.
Dec 06, 2011 | Proform Exercise & Fitness
I need a wiring diagram for a pro form 730 treadmill
There are many different kinds of Proform 730 models. Please search for or find your specific Proform model here and look at the parts list for the accurate wiring diagram for your model.
Oct 20, 2011 | Proform 730 Folding Treadmill Model...
Require the wiring diagram for a proform treadmill petl3013 version7
Got to iconsevice.com you may order the tech sheet for a minimal cost, but unfortunately they are out of stock PETL30130 - PROFORM 360 P TREADMILL
May 08, 2010 | Exercise & Fitness
Hello I am having problems with my ProForm 540 panel board on the treadmill. I cannot put in my speed manual. I can select a program on the left side of the panel. Please help!!:)
Sounds like your function key has failed and needs replacing if this model offers it they may want you to purchase the entire console so go to iconfitnes.com or call them @ 1-800-999-3756
Mar 03, 2010 | Proform Crosswalk 500 Treadmill
Console buttons don't work,only ifit button works
Has anybody found the solution for this? I'm having the same problem on my 850T treadmill. It's really annoying..
Feb 14, 2009 | Proform 540ls Treadmill Walking Belt
Exercise & Fitness Logo
530 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
