I want to know if I should try and replace proportioning valve?
Did air get into the master cylinder? If you can, try bleeding the master cylinder. The fact that you aren't getting any fluid out of the line suggests that the master cylinder isn't pumping fluid.
Master cylinders are (usually) on a split circuit system - that is, the front left brake is on the same line as the rear right. The front right brake is on the same circuit as the rear left.
A point to be aware of is when bleeding brakes/doing brake work and if the master cylinder runs dry, is that a seal inside the master cylinder can fail/twist over and not pressurise that particular line, even though it may pressurise the opposite brake line.
I'm in the UK. I have a 1998 Jeep Grand Cherokee 4 litre, which I am slowly rebuilding. Three weeks ago I fitted new front brake rotors, new front callipers and pads. I've been rebuilding cars for over 40 years now and have done countless brake overhauls.
.. and could I get a hard pedal after the job was completed? I must have bled the brakes three times a day for a week and couldn't get a brake pedal. I phoned a full time mechanic I know - he came and tried to bleed the brakes three times and couldn't get a hard pedal.
That's when you think 'The master cylinder was working before I started the job so it must be still working now'.
I fitted a brand new master cylinder and because some parts for older jeeps are hard to come by in the UK, I fitted a second hand proportioning valve. When I bled the brakes again the pedal became rock solid. Fixed.
You're probably fed up with your braking problem now ... and apparently this 'no fluid/brake pedal' is more common than you may think.
Try bleeding the master cylinder if you can. If you suspect that it isn't fully working - try an overhaul kit which is cheaper than a new master cylinder.
As for changing the proportioning valve .. that's your decision. My brakes now work though the truth is I don't actually know which was at fault as I changed both the master cylinder and proportioning valve at the same time. Maybe both were at fault, for whatever reason. I genuinely don't know.
The positive aspect is that you are doing your own work and know what you're doing. You're saving on labour charges.
