Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony TV not turning on
Sony Trinitron TV (KV 27S10 circa 1994) suddenly dead. Was working fine till last evening. Was turned off normally but did not work when turned on this morning. Pressing on the power button does not do anything
Power outlet is fine as other appliances work fine when plugged into same socket. Any diagnostics that can be performed ? Great TV better than my newer WEGA but want to make sure TV is fried before I throw it out.
  • dsbandy Jul 18, 2009
    thank you for your reply now for the rest of the story. The TV was turned on and while they were watching it simply went dead and will not turn on any longer . I suppose this would fall into the same issue you described?
  • 668 Answers
Chances are the Power Supply failed because the Horizontal circuit failed. It would not be out of line if the repair cost ran 250.00 plus.
It is probably not worth fixing due to the age of the set.
Hope this helps,
Skyassoc
Posted on Jul 17, 2009
  • Steve Yocum Jul 18, 2009
    It sure could. These sets were good but it seemed the Horizonal Output circuitry failed more than it should in my opinion.
No Power Sony KV-27FS12
IF the unit is completely dead (no standby light at all) then teh main fuse is most likely open. Try replacing that first. If the stnadby light is on, then when you attempt to turn it on, the light shouild blink. If so, the blinking should be a repeated count with a short pause between sequences. Post that count here as it will indicate what circuit has the problem. We will continue from there.
Thanks,
Dan
Feb 11, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Tv won't turn on
i can' turn on my sony tv . no lights are blinking. nothing. could something when it was moved.
Dec 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Model KV-27S10
If hte set is a Sony, the standby light should be blinking a code. Report that code here and we should be able to guide you. That code will indicate the problem circuit within the set that has the fault.
Thanks,
Dan
Jun 02, 2008 | Televison & Video
Sony Trinitron Color TV - KV-27TS27 circa 1991
there,s a lose connection on vertical section of your tv. to resolve that to \resolder the vertical section but be careful of short circuit t may damage your system
Feb 28, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Trinitron sony kv-27S10
your problem is very simple,reheat or resolder  the high voltage section it is located near the flyback, I'm sure it's only loose contact.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Trinitron KV-36FS13
The problem is in the standby power section. Check the fuse, R607, or burnt IC601, fuse R612 and VD relay 601 should show open. Its possible it could be the high voltage area of the power supply. You can try unplugging the set and cable and let it sit 4 to 6 hours. This is a hard reset. If it still doesn't turn on after the hard reset and the fuses and relays are fine, and you don't smell anything or see anything burnt. Then you'll need to call a TV repair man. They normal start around $150-$200 to fix the set. I hope this helps.
Jul 10, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron KV-28WS3U Dies
B+ over current protection (OCP), unit goes to the standby mode. Could be a short in the power supply of any of the circuits.
Nov 05, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
438 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
