Question about Vizio L32 32 in. LCD HDTV
Got a 32 inch vizio. a year and 4-5 months old.. plugged in.. and doesn't turn on. worked in the morning, came home from work, didn't work.
  • 979 Answers
Good day sir, that usually happens to my PC. I usually bring it to work and somehow doesnt work in the office. this is due to transportation jitters, some components seems to get dislodge or parts get disconnected, wires get tangled. Im afraid that there are parts inside your tv isnt fixed with screws well. the only way to solve this is to check the internal parts of the TV module by module. and locate the culprit. hope this helps. thanks
Posted on Jul 17, 2009
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
Vizio L32 stopped working.
I have seen this many times. The tv most likely has run its course. It could be the power supply or a lamp. Sounds more like a lamp, as you still have lights on your set. check around and get some prices on a lamp. you can have a local shop install it for you. or just replace the set.
May 03, 2010 | Vizio L32 32 in. LCD HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio 32 no power
http://www.encompassparts.com/models/?VIZVW32LHDTV10A justmanuals.com
do some research, pick out a weekend, and then replace that power board! save yourself some $$$ but make sure you order the right part and know what you are doing before you start.
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
Hello. I have a Vizio 32 inch LCD flatscreen TV. About 5-6 years old. Once on, it works fine for a minute or two but then the screen goes blank and the orange Vizio blinks on and off. Every time. Does...
this is a main board problem. Replacing this will resolve the problem for you. if you want a tech to come to your home and fix it for you, you can call ITI at 888-248-2708
Jun 18, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
32" VIZIO PROBLEMS
The main board is bad. I have seen a lot of TV has the same problem like you have. Replace main board will fix it. If you bought these TV from Costco and less than 2 years then they all still under warranty.
May 05, 2009 | Vizio L32 32 in. LCD HDTV
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Vizio 32 inch now shows mostly only green and red colors
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD
Nov 30, 2008 | Vizio L32 32 in. LCD HDTV
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
May 03, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
77 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
