Question about Pioneer CDJ-800 Turntable
CD automatically ejects
When I load a cd it automatically ejects; I tried many cd's and this still persists.
Appreciate any advice.
Thanks, Chris
  • 68 Answers
Re: CD automatically ejects
Possible slot mech or laser pick-up fault,if you havent had it repaired you can send it to us.
Posted on Dec 03, 2008
  • 515 Answers
Sounds like a tray issue. Unfortunately the only option is to have the tray replaced.
Posted on Dec 02, 2007
0 characters
3 Points
Vestax CDX-05 stutters and clicks when ejecting cd. Not all the arms on the transport assembly move when trying to eject a cd.
well to be honoust, it would be the best, but not price wise. I can't help you, only let a pro look at it with you by your side. It turnds and grabs the side and yesterdat i reard that loose components can be installed......
Dec 18, 2012 | Vestax CDX-05 Turntable
When i turn on my cdj 400 it automaticaly ejects and loads cds constantly even tho theres no cds in it ?? it only stops once you load a cd or use the usb help plse..
That is really weird. so it says ur putting a cd in and ejecting the cd?. im not sure about those models but if theres a reset on it i would try that before sending it out.
May 20, 2011 | Turntables
Cd wont load
More than likely your loading motor, or the traverse assembly are damaged, and need to be replaced.
In either case, it is highly suggested that you contact a qualified service technician with this type of repair.
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 09, 2009 | Pioneer CDJ-800MK2 Turntable
Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
3rq8 (Triarcuate)
Aug 08, 2009 | Crosley CR248 Turntable
Cd mounts but doesn't start on cdj-100s
you need to replace complete assy. of ur decks.
Jun 09, 2009 | Pioneer CDJ-100 Turntable
Need driver for windows to have the Crosley CR249 turntable work correctly.
Insert the enclosed software cd into your computer.
Follow the instructions on the computer screen to install the software. If the software does not load automatically, browse the cd and open the Read Me folder for further instructions.
Connect the small end of the USB to the USB jack on the back of the unit.
Connect the other end to a USB port on your computer.
On your computer open the Record Recording software.
For instructions on operating the Record Recording software, browse the software cd and open the Read Me folder.
I got that from the manual. You don't need a separate USB driver for it, mate, but you DEFINITELY need the cd...
Hoping you have the cd,
Chris (ziraffa)
Dec 28, 2008 | Crosley CR249TA Turntable
When my cdj turntable is powered on it begans to eject repeatedly even though there's not a disc loaded. I've attempted to correct the problem by restarting several times, adjusting the controls and using...
Your CD tray is damaged, or the loading mechanism/motor is damaged - or both. Unfortunately, not an easy fix. You'll need to take it to a service center for repair.
- Optic
Sep 14, 2008 | Pioneer CDJ-800 Turntable
Cdj 100s
hi! my pioneer cdj-100 has not ejecting cd
Feb 23, 2008 | Pioneer CDJ-100 Turntable
Pioneer CDJ-800 Turntable Logo
233 people viewed this question
Top Pioneer Turntables Experts
Dennis McCollum
Are you a Pioneer Turntable Expert? Answer questions, earn points and help others
