Question about Canon imageRUNNER 3300 All-In-One Laser Printer
The machine keeps giving paperjam error when the top paper drawer is used. The paper moved up a little on the right side then stopped. The correct paper size (LETTER) is set with the blue wheel on the drawer. I had to pull out the drawer and put the paper back in the tray, then open and close the side door to clear the error. Thank you very much in advance.
Sounds to me like the feed tires are worn out, and need replacing
Posted on Jul 17, 2009
My HP Laser Jet 4730 is not feeding back through the Duplexer causing paper Jam in side top right panel.
There is a known issue with this series and what happens is that the paper exit flag sags from the heat of the fuser and interferes with the paper path. One small $10 dollar part but you have to take a lot of parts out to get to it. You can see this flag if you open the front drawer where you remove duplex jams, it is right behind the duplexer.
Dec 04, 2014 | HP LaserJet Office Equipment & Supplies
Machine does not "see" top tray with A4 paper. It seems to be expecting a side feed of paper. Prints on A3 if top drawer removed.
make sure the arm of the paper tray that runs from left to right is fully against the paper and that any keyway is correct take out the drawer turn it over and check nothing has come adrift
Jun 18, 2010 | Toshiba E-studio 281c Copier
When I switch on an error is occuring : Dredgdraw
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
The white thing on the side is for the cappuccinatore. It slides on with a twist. The hose goes into your milk. You twist the little knob on the top when it is steaming until the milk goes up the tube and produces the foam. Once you get the foam going you won't have to move the knob again. Just keep everything clean.
Dec 29, 2009 | Saeco Royal Professional Espresso Machine
Canon irc3380i paperjam
This problem fault manual presenting the track. Follows to consider several reasons. Check the condition rubber roller seizure of the paper. Check and clean lower brake platform. Check and value the possible ragged sheet of paper. Check presence a stranger subject in giving device. Try to give the paper along on format by narrow side. Thank you, good luck!
Sep 16, 2009 | Canon C2058 Color Copier
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
My NP6012 stops and paperjam light comes on. Paper not being fed.
Pick up wheels can be full of dust due the time storage.Keep on trying to make copies,the paper will clean the rollers every time it try to feed.
Jan 28, 2009 | Office Equipment & Supplies
''place paper in drawer''
Sounds like a paper sensor ; A little black arm that senses paper tray is full, when the tray lifts into position. You might pull the tray and with a flashlight look for any broken parts. I have seen these break when paper jams are removed. This is a Toshiba 2860 correct?
Nov 18, 2008 | Office Equipment & Supplies
Lanier lp126cn
I would need more information for this fault. Your "question" is very criptic.
Are you getting a paperjam error, or is the machine not picking up the recording paper or the document feed?
Did you have a paper jam and clear it, but not all of the paper came out? If so, unplug the machine and open the upper cover. On the right you should see the print head under the top cover (you may need a light). See if you can grab the head and move it. If you can move it then it's not locked. This usually means the machine has a clump of wadded up paper stuck in it somewhere. This paper is usually on the right side between the head and the outer case. You might be able to see it if you shine a flashlight in the area where the head goes AFTER MOVING THE HEAD to the left. If you can see paper in the head maintenance area, you'll need tweezers or something to pull it out. If you can't see anything on the right side, look in the same area but on the left side. If you do see paper on the left side, be careful not to damage the encoding wheel while you're trying to remove the paper.
If this doesn't help, please provide more information.
Dec 21, 2007 | Brother MFC 420CN All-In-One InkJet...
My indset washing machine
most soap drawers have a little springy thing you press to allow it to come out, this stops it getting pulled all the way out by mistake, pull the drawer out as far as it will go gently till it stops then look for something that will move on the top where the soap goes, try pressing it, sometimes it is a different colour, if you found this the drawer will slide out when you press this bit, if there is nothing that moves or nothing to press then give the drawer a little bit extra force ( a short sharp tug) and it should just slide out that last little bit, to put it back just line it up with the slides and push gently back into place, it shouldn't be forced too hard to do this, it should just slide back
Sep 25, 2007 | Zanussi FJS1225W Front Load Washer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
50 people viewed this question
old marine
old marine
