Point the remote at your phones camera and press a button on the remote. You should see a flicker from the infrared led on the remote. If there is no flicker then the remote is broken.
This is the technical solution, you have to open the unit: Locate IC33 and connect pin 6 to ground, connect power, and then remove the ground connection at pin 6. The unit will then boot up in factory default.
1= change the batteries by new ones 2= clean the contacts cleaners with contacts cleaner 3= resolder the wires contacts batteries 4= retight the spring contacts batteries with pliers for better contacts 5= open the r.control clean the kepayds switch for dirty, oxide, and test for open, bad contacts. 6= try agan, if doesnot work go to the repair shop TV for fix it.
Have you tried fresh batteries? try that first , if not successful , get a digital camera and point your remote control at the lens while the camera is on, if you see a white blinking light then the remote is fine , if you see nothing buy a new remote control .. it can be a problem with the infared amp inside the dvd player if all else fails.
Hello Check the remote control for its infrared emission. If it is found OK, and still your device does not respond to remote control, the infrared sensor inside your device is faulty and should be replaced. Just enter into the following link. You can understand how a remote control can be repaired or cleaned. Do this first. The remote sensors can be located just behind the infrared sensor window of your device. You have to open your device to access it.
