Question about Bosch Dishwashers
I am having problems with the white scale being left on the inside of the dishwasher and I am not sure how to add the rinse agent to the despenser to stop the streaking and spotting. My model number is SHX46A
1) Do maintenence as suggested in operators manual
2) Buy 3 (yes 3) Dishwasher Magic (ACE carrys it)
3) Run all 3 - NO dishes
4) Load dishwasher with 3 cups white vinegar
5)Run cycle with Glasses only
6) NEVER USE LIQUID AGAIN - powder only!
Posted on Aug 27, 2009
White film left on the dishes after going through the dishwasher. Why?
Too much rinse agent. If you are using powder or gel, set pointer knob on rinse agent dispenser to a lower setting. If you were using the tablets, they have rinse agent built into them, and the additional rinse agent from the dispenser equals a double dose, so the film shows up. Stop using tablets until liquid rinse agent dispenser is empty.
Apr 14, 2011 | GE Dishwashers
Hello, our Kenmore dishwasher's rinse agent dispenser is overflowing and won't empty. We haven't been able to add vinegar (all we have ever used in it) for a very long time. The dishes are definitely not...
Open the cap to the rinse despensor.
There is an arrow in the center that turns.
Turn it a click or 2 toward the dish washer bottom.
The more it faces the bottom the more rinse agent it will despense.
I hope this helps you....
Aug 08, 2010 | Dishwashers
Doesn't clean properly, Leaves dry residue in washer
My dishwasher had the same problem. glasses were cloudy, inside the dishwasher was coated with a film, drawers were hard to pull out. tried rinse agents and vinegar and nothing worked. Found lemi-shine at WalMart (it's next to the dishwasher detergent) and the white stuff is gone! no more residue and glasses sparkle again. I was ready to buy a new dishwasher I was so frustrated. get some - it's amazing! a couple bucks and it's back to normal. I was SOOOO happy!
May 21, 2010 | Siemens 24 in. SL84A305UC Built-in...
Whte residue left on glassware and dishes
use a dishwashing cleaning agent in the machine. or some thing the has a grease cutting agent.run this on an empty cycle.
there are times residue grease and oils can accumulate down in the sump area where the water sits and can cause film on the dishes.
this could also be some lime or scale build up for that you can use some C.L.R or any kind of lime and scale remover to clean your machine.
make sure tht that this is done on an empty dishwasher
May 19, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Funky smell and a fim reamin on dishes after
You can clean your dishwasher with either a product called "Dishwasher Magic" or white vinegar. Both are basically food safe acids in low concentrations, and will dissolve the hard water scale that builds up in dishwashers. You also should make sure you use rinse agent "Jet Dry" all the time unless you have a water softener.
Jan 03, 2010 | Kenmore Dishwashers
Dishes will not rinse, white residue, using rinse agent
Look inside and see if all the water is gone at the end of a cycle - none standing in the bottom of the washer in the sump.
Apr 05, 2009 | Jenn-Air Dishwashers
The inside of my stainless steel dishwasher looks as if it has a white film on it. My glasses are also looking like they are etched. I haven't changed the dishwasher soap...any ideas what is causing...
are you using a rinse agent such as jet dry( you should be) and if your using tabs with rinse aid built in dont add extra rinse aid to dispensor, . water temp might be an issueperhaps some detergent has gotten into the rinse aid compartment mistakenly
Nov 04, 2008 | Dishwashers
Dishes come out with white stuff all over them
Dishwashing detergents have recently been re formulated and sulfates were removed. This has caused the dishes to no rinse properly in areas with hard water. The solution is too add a rinse agent containing citric acid. I got some today from our local appliance store and the dishes came out perfect!
Jul 15, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishes and inside the washer are not drying
Make sure that the drain hose is connected as per manufacturer instructions, and that there isn't a direct run down from the sink u-bend to the machine. The rinse agent effects dishes dry but has nothing with the water remaining in the machine. Good luck!
Sep 15, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
238 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
