Defy DMO343 Microwave I was at Defy Upington but they don't have lights. I can't continue to pay R60 per bulb that does not even have a life span of 1 month.
SOURCE: Lightbulb no longers turns on!
They do this to avoid liability from your exposure to the instantly lethal voltages present in and generated by your microwave oven. For important safety and disassembly tips, search on Yahoo.com (not Google) for all this at once (copy & paste): microwave disassembly.txt safety.txt The oven must first be disconnected from the power line. The outer cover is held in place by several screws on the back and sides, then you lift up and back from the rear to remove it. You need to avoid the sharp metal edges on thge cover and inside the oven. Note there are also catches built into the top & sides of the cover which must be re-engaged upon reassembly, or the cooling efficiency will be compromised. Once the cover's off, if there's any chance you might come into contact with any of the high voltage connections, the high voltage capacitor should be discharged for safety's sake. Once the bulb is located, it can be unscrewed and replaced.
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
SOURCE: how to change light bulb under microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
The first step is to unplug the oven before changing bulbs!
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
http://www.microwavedisplay.com
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a
microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
