Question about Lite On K17AN (Beige) 17 in. Flat Panel LCD Monitor
DVR-K17a Good afternoon.  My computer doesn't recognize my DVD - doesn't see it at all.  Please provide driver or firmware for it.
0 characters
1 Points
Drivers for Hans.G JC199D monitor
Question: Does Hanns.G provide Windows (or other) drivers? Answer: Answer: No Operating System specific drivers should be necessary. Hanns.G monitors comply with DD2B plug & play standards.
In other words hans doesn' t need drivers, it is plug and play
Jan 28, 2015 | Computer Monitors
Bosch 650 dvr says disc error
the cause is either the disc has a problem which does't recognized or the optic lens and the spindle motor not working. you have to check this part first.
Mar 25, 2013 | Bosch DVR-650-08A100 - 650 Series Digital...
Samsung SMT-H3270 DVR not responding at all
The DVR unit still have power and display functions on the DVR small LED screen indicator on the DVR unit correct?And the DVR unit have not been in used for awhile and alway been plug in the power outlet for power like 24/7 hrs for power correct?Yes to all these questions,possible the DVR unit have software lockup or power glities some where before,possible the DVR unit have lockup and looping the software firmware of DVR unit not responding correctly for to the DVR unit to work or responding to any screen display functions.Tries unplugging the DVR unit for like about an hour and plugging power it back in for the DVR unit for the software to reboot itself.90 to 95% the unit will work again as u first got the DVR unit.
Oct 28, 2012 | Computer Monitors
The monitor is currently black, power is on, I press screen saver and it come on for about a second and goes dark again
It can be one of two things:1. A power issue2. A firmware issue
1. In the first case the one thing you can do is to power off the device, unplug it, wait about 5 minutes and then press and hold the power button for 20 seconds with the cord unplugged. This way you will deplete the capacitors in the power section of the device. If that doesn't work it's most likely the internal power transformer or one of the capacitors is toasted. In this case you must go to pt. 2.2. In the second case you can't personally do anything because you must address the issue to a certified Samsung service provider in order to examine the issue and perform the firmware rewrite or the intervention needed to repair the device.
Hope this helps, keep me update please,Vlad Mototolea
Sep 26, 2011 | Samsung SMT-190 19" Flat Panel TFT LCD...
Windows XP SP3 does not recognize the screen size of 1440x900, or any resolution other than 1024x768/800x600 It's a Westinghouse L1975NW, running off an Intel 945 Express Chipset
Problem might be with your graphics drivers
Confirm by following process
Right click on my computer and then click on Manage.
then Choose device manager from left panel of the window
then list of hardware will appear.
if there is exclamatory mark over your graphics drivers then right click on it and then click on update device software
if it doesn't work then install it from your drivers disk, you got it with your motherboard.
May 17, 2011 | Westinghouse L1975NW Monitor
Good afternoon. I have an LCD . When I turn it
Sometimes LCD screens can flicker if kept in cold environments. Make sure that it's not too cold in the area of the LCD. Also, make sure the cable to the monitor is connected properly, as a loose cable can also cause the screen to flicker.
Mar 05, 2011 | Samsung Computer Monitors
I want to update the firmware or drivers for this monitor ''LCM 22w2'' (ca. 2006) but Westinghouse's website doesn't recognize the serial number and their tech support is closed on weekends. Is there...
don't need to update cuz it's not recommend to do that if it's not broken!!!!!turn on ur computer in mode safe wih network then try to recovering disk procedure(use the help menu or or the manual of ur pc) to ask to the system to restart the system few days or more before the updates cuz whan u allow automatically updates,it happens sometimes that the system becomes instable.when u will do this recovering procedure go and change this setting!!!!There is a condition for recover the system but i use windw and i don't know anything wit mac.DON'T update the firmware cuz u will have more problems if the system doesn't recognize components of ur computer and u will change them and u don't really need to do that!!!!just try it,be patient and stay calm, it happens to me and if i solved that, u can do that to.
Sep 13, 2009 | Westinghouse Electric LCM-22W2 Monitor
LG Flatron L1750H
Hi there, my name is Alex and I am here to help solve your problem.
When adding a new monitor to your computer, it is not necessary to install the monitors drivers as it should detect 'Plug and Play monitor' and will install the monitors drivers automatically. Are you getting any error messages?
If you have any questions or needing further assistance, then please contact me.
Oct 10, 2008 | LG Flatron L1750H (Silver) 17" LCD Monitor
Lite On K17AN (Beige) 17 in. Flat Panel LCD Monitor Logo
330 people viewed this question
Top Lite On Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Lite On Computer Monitor Expert? Answer questions, earn points and help others
