There is something wrong with the mechanism, either the main drive mechanism, or the cassette holder part. Possible physical damage to the plastic parts. When the tape is inserted a device called a mode switch tells the electronics which position both mechanisms are in. If they go out of sequence, due to damage, or a faulty mode switch, the electronics shut the system down to prevent tape damage. When you power it up, the system thinks it is eject mode and chucks out the tape.
SOURCE: VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
SOURCE: VCR runs a few seconds when I insert a tape then shuts off power.
You have to change the two VCR rubber bands
Jc
[email protected]
SOURCE: magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
Try better quality VHS tapes or 6-hour tapes instead of 8-hour ones. I had this problem myself when I used 8 hour tapes, but haven't had any problems with the 6-hour ones.
SOURCE: when I insert a video cassette into my magnavox
Try a video head cleaner first of all, OR eject the tape before turning off power.
