Question about Acer AL1916W 19" LCD Monitor
The Acer monitor's horizontal and vertical is set
The Acer monitor's horizontal and vertical is set at 50%. How do I incease it?
  • 98 Answers
Use the function button on your moniter and scroll until you see the setting you want to change and increase it or decrese it from there.
Posted on Aug 03, 2009
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Troubleshooting
There is a setting on the computer screen, it will say vertical and horizontal shift, There is buttons on the monitor to get to the menu to get to screen shift settings.
Jul 12, 2013 | Acer AL1914 19" LCD Monitor
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
I have a x223w monitor that if you try to set higher than1280 x 768 it stretches eveything horizontally
Does your video-card allow you to set a resolution of 1680 by 1050?
(This is exactly 16 pixels horizontally for each 10 pixels vertically.)
This is the "native" resolution of the X223W monitor.
If not, pick a supported resolution that keeps the 16-to-10 ratio.
Sep 10, 2009 | Acer 22" X223w LCD Monitor
Acer 2223W monitor stand
There are indeed generic stands which rotate between portrait and landscape orientation. This monitor, like most monitors sold today, has generic "VESA" mounting holes, in the 100mm x 100mm (MIS-D, 100, C) configuration shared with most other flat screen PC monitors, so they can easily be used with a variety of stands that attach to the 4 holes in the center of the back side of the monitor.
Apr 05, 2009 | Acer AL2223W 22" LCD Monitor
Monitor is vertical display instead of horizontal display
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Acer top and bottom of screen is blank
on the monitor press the menu button in that adjust the horizontal and vertical size correctly ... you will having the option to adjust in the menu button ...
or you may be using some low resolution check the display properties set your resolution to 1024 x 768 ...
this will fix your problem ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 12, 2008 | Acer Computers & Internet
ACER AL 1716
There are two types of lines.
Lines caused by a bad LCD screen and lines caused by poor sync.
A bad LCD will cause perfectly straight vertical and horizontal lines that don't move at all. This is because the row and column addressing ICs have gone bad, so you will end up with rows or columns of bad pixels.
Poor sync looks more like what you are describing. The picture will flip vertically and horizontally.
Poor or missing sync can be caused by a bad video cable, or a bad IC on the main board.
If the monitor has a removable video cable, borrow another one from a friend to test if the monitor is working. If it works, head to your local computer store and buy a new cable.
If the monitor still doesn't work with a different cable, you may have a bad main board. The only way to repair the monitor will be to replace the board.
If you open the monitor, be sure to check for bad capacitors. They can cause all sorts of strange faults. Look elsewhere on this site for how-tos on inspecting capacitors.
If your video cable is not removable, there's not much you can do. You will need a way to test that each pin on the cable connector on the main board conducts to a corresponding pin on the other end of the cable. You can do this if you have a multimeter, or a continuity tester.
Mar 28, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
487 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
