Canon PowerShot A75 Digital Camera Logo
Posted on Jul 16, 2009
My canon a75 continually says low battery after changing them
I have changed the batteries three different times each time a new brand and it still says low batteries... Please some one help. I cannot continue spending money on batteries that it is not reading.
Anonymous
Level 1:
  • Contributor 14 Answers
  • Posted on Aug 21, 2009
Anonymous
Contributor
Level 1:
Answers
14
Questions
Helped
9661
Points
41
Cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
1helpful
No power
All I did this a couple times in the service but I will not renew the camera again to ukljuci.What's the problem?
2helpful
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
My canon powershot a495 has a problem. it always shows low battery and turns off. i have changed to new batteries three times but the same problem. i bought 3 months ago. help please thanks
my canon powershot a495 has a problem.
1helpful
3answers
Camera won't turn on
1. Most likely is discharged or improperly inserted batteries. Make sure to use freshly charged AA batteries that are inserted with the correct polarity. The Inner 2 have the minus side up and the outer 2 batteries have the + side facing up.
2. Close the battery door fully because the battery cover pushes on a small sensor that has to be closed before the camera will turn on. The battery cover slides and clicks into place. If the battery cover sensor is bent or damaged then the camera would not turn on. The battery cover sensor is tiny, and out of the way and probably not obvious that is has one.
3. Insert the proper memory card and close the memory card cover securely. If it's left open or not seated fully the camera may not turn on. I
4. Also remove the memory card and re-seat it, then close the cover again in case it was not fully closed.
5. Remove the batteries and check that the battery terminals are clean and they appear to be intact. For example, corrosion from leaking batteries could cause a poor connection.
6. Was the camera dropped? If it was dropped that can bend the metal battery contacts, then when you put the batteries in it doesn't really contact the battery properly.
7. If it still won't turn on have an electronics guy check it over, or at the local college electronics teacher. I've fixed these before and the main DC circuits are not too complicated. These camera's can even be powered up using a regulated 6V DC power supply connected properly to the battery terminals, (just for testing) and in that case you don't need batteries to tell that the camera works or not. These draw about 300mA of current when ran from 5V to 6V DC.
I attached a JPG photo showing a similar Canon A60 running via a DC power supply and no batteries. This one was apart at the time to fix a stuck zoom lens, and when it's apart there is no where to put the batteries so I have to power it this way.
You do not have to take it apart or use this method. I just mentioned this so it's clear that all it needs to run is 5 -6V DC from properly charged and inserted batteries (or an external source). Don't try connecting anything if you are not familiar with electronics because connecting it up wrong can damage the camera. Try the suggestions mentioned early and it will probably work since these are pretty reliable cameras.
15helpful
2answers
Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
7helpful
Powershot SX100 low battery symbol with new batteries
Hi!
If you're sure that the batteries are full, then the power board has to be changed. It's the first board under back cover, with the buttons on the other side of it. Contact your local Canon service center. If they ask very much, you can contact me [email protected] and I can give you a price - I have access to new Canon parts.
Tom
22helpful
2answers
Change the batteries message even with new NIMH RShack batteries
The solution is to change the small 'date/time' battery. You can have the regular batteries as charged as you like, it won't make any difference. The tiny date/time battery is in the same compartment as the regular batteries, on the opposite side of the hinge. Extract it with a fingernail, it is situated on the left hand wall of the battery compartment (when the camera is inverted and the compartment open).
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
