Question about Jenn-Air Cooktops
None of the burners on my CVG4380 will light - Jenn-Air Cooktops
  • 1 more comment
  • cliffb930 Jul 17, 2009
    None of the burners working on my Jenn-Air CVG4380. Has not been wet.
    No sparking sound on any burners. Leads me to assume spark relay bad ???
  • cliffb930 Jul 18, 2009
    Where would that be located on my model? Thanks!
  • 2,359 Answers
My answer is for the GAS version of CVG4380 downdraft cook top.
If you have an electric version then please let me know.
CVG4380 GAS downdraft unit has safety device call APPLIANCE PRESSURE REGULATOR.
In even the gas get shut off and restart. The natural gas may not able to purge though the regulator.
This unit is directly next to the grease container and blower.
There is a wiring box for the controls.......I will not recommend servicing it.
Good luck
Posted on Jul 18, 2009
    President:
  • 512 Answers
Are the burner ports clogged?
If burner ports are clogged, refer to your Use and Care Guide for sealed surface burners cleaning recommendations. If you do not have your Use and Care Guide, find it online by entering your product model number in the search tool below.
Clean the ports with a straight pin. Do not reassemble caps on burners while wet. Replace the burner cap, making sure the alignment pins are properly aligned with the burner cap. Do all burners fail to light?
Check to see if the cooktop is connected to the gas supply and the gas shutoff is turned on.
Do you hear a sparking sound?
If there are sparking sounds, the igniter may not be sparking to the burner cap. Turn off the appliance and check to make sure the caps are set on the correct burner base properly. Do not switch the caps from one burner to another as they may not spark properly. Each burner has its own individual cap.
Is the burner head positioned properly?
Cap must be seated on the burner base to light and perform properly. Reinstall the burner cap, making sure the alignment pins are properly aligned with the burner cap.
I have given you a bunch of things to do, one of these should solve your problem. Mostly sounds like burner caps need to be cleaned, gas causes build up of carbon.
Details None of the burners on - arrows_down.gif Answer ID 439 Products Cooktop Gas Cooktops Range - Gas Drop-In Freestanding Slide-In Date Created 07/14/2006 05:08 PM Date Updated 06/01/2009 01:59 PM -->
Posted on Jul 17, 2009
  • Frank Meola Jul 17, 2009
    You have checked everything to the igniter, no spark, has to be igniter relay. Replace and you should have ignition. You pretty much solved this yourself with alittle help, good job.
  • 3,741 Answers
Burner will not light: There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are theignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help. click the link directly Repair and checking tips for surface burners. Please do rate the solution. Thank you for using fixya.keep updated. thanks.
I have a cvg4380 and I need to replace the igniters , how do you remove and replace the igniters
The link below shows the different parts for that unit. There is a button under the items that says watch video.
http://www.appliancepartspros.com/search.aspx?model=cvg4380
Feb 18, 2017 | Jenn-Air Cooktops
I have a 6 burner range top. When I turn on 5 of the six all 6 spark as they should and the correct one lights. When I turn on the left front knob none of them spark and it will not light, but gas does...
The problem is the burners switch the the single burners has failed, this will cause is not to fire the module and ignite the burner. I would replace just that burner switch to correct the problem. When you call for parts, make sure you have the complete model number and possible color of that burner switch needed. They make or have available switch that are sold by color, so color may be needed for this model.
I hope this helps.
Sep 20, 2013 | Viking 37 in. VGSU161 Gas Cooktop
None of the burners igniter clicks so none of the burners will light. Could the spark module have gone bad?
That is definitely a possibility. If you can find the module you could disconnect the wire going to the switches (at the valves) and then hook up the module to 120 volts. Careful! Don't get shocked.
May 24, 2011 | Amana 30 in. ACC3660 Gas Cooktop
GE Profile glass top cooktop- burners do not heat, indicator lights do work
If none of the burners are working but the pilot light does you are having a power problem and only getting 120 volts to it. Check the breakers to make sure they are on correctly. 240 volts is needed to operate the cooktop. Hope this helps. Rick
Mar 09, 2010 | GE Cooktops
Can't turn on KECC508 cooktop I didn't buy it and it is in the house and the light in the middle to power all burners off is lit.
The middle light is the lock. You must hold it down for at least 7 seconds to unlock it, then the middle light will go off. Your hands can't be wet, or none of the buttons on mine work right.
Dec 17, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
GEXL44 burners light with match, but not with electronic ignition
if u push the knob there is a clicking sound, if no the problem is damage the ignition coil, need to replace it,or check the outlet,plug or its batery operatet ignition? replace the batery.
the ignition is power operated,check the power source.
tnx gerbee
Jun 22, 2009 | GE Profile JGP636 Gas Cooktop
Maytag MEC5430 cooktop burner indicator lights not working
If indicator lights are all that wont work there is a "P" terminal on the surface switches (unless they are controled through a board). The P is for Pilot And 1 side usually the "P" terminal of the switch is allowing the light to recieve the power signal that the element is recieving from the switch. The other side of the pilot light(s) will all be wired together at a "common" pont.
My guess is that if you have individual piolet lights this common point is not tied in to the circut now. 1 wire off or loose and none of the lights work. However it should be simple to trace back to this point and effect repair to it.
Jun 12, 2009 | Maytag MEC5430 Electric Cooktop
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Oven Striker
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Oct 12, 2006 | Dacor Preference SGM466SS Gas Cooktop
Cooktops Logo
73 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
