Question about HP Office Equipment & Supplies
Print cartridge cradle is stuck
My hp 7760 says print cartridge cradle is stuck and there is no jam does anyone know how to fix this? Thanks
I'm no expert, but try the easiest solution first. This happened to my hp 1215. The problem for me was one of the covers over the ink cartridges itself that snaps the cartridge into place had a little play in it and stuck up a bit higher than the other one. When the cradle moved all the way to the left, that cover rubbed on the outer covering of the printer. I simply taped it down and solved the problem!
I hope it's this easy for you!
Chris
Posted on Jul 23, 2009
    Novelist:
  • 109 Answers
Try turning off the printer, disconnect the USB cable, uninstall the printer drivers in "Add and Remove Programs", reinstall the drivers and reconnect the printer. Printer problems are more prolific than any other problem with any other computer accessory. Drivers become corrupt for no apparent reason other than Windows feels like doing it. If this doesn't cure the problem then I would suggest GENTLY trying to dislodge the cartridge cradle just a little bit (don't force it side to side). It shouldn't stick but who knows. If it does move OK again, listen for any odd sounds coming from the printer. My guess is still a software/driver problem.
Posted on Jul 16, 2009
Screen says cartridge cradle is stuck but it moves freely
Ok there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PhotoSmart 7760 InkJet Printer
Hp photosmart 7760 print cartrige cradle is stuck.this happened after i ripped a paper jam out
try to move the cartrige cradle to left and right for about 10 to 11 times. if the issue still persist you may need to service you printer
Sep 27, 2009 | HP PhotoSmart 7760 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Get error message on my HP Photosmart 7760 that "Print cartridge cradel stuck. Clear jam then press okay"...but there is no jam. :( Help...thanks.
jam not on the paper but, check the space where the printhead slides on, see if there is something blocking the path
Jun 26, 2009 | HP PhotoSmart 7760 InkJet Printer
Print cartridge cradle is stuck error message
The cartridges & container must be removed and reinstalled.
Apr 03, 2009 | HP PhotoSmart 7760 InkJet Printer
HP photosmart 7760 turn on and says printer cartrage cradle is stuck please remove jam and press ok. There is no jamb and I have tried many times to use the printer.
try to move the carriage manually left and right..and then disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.Make sure the unit is connected directly to the
walljack.
Nov 30, 2008 | HP PhotoSmart 7760 InkJet Printer
solution for...
" CARTRIDGE SEVICE STATION IS STUCK " with a blinking red light...
it's a bit difficult...just fixed it today....
first of all...u have to be sure that your service station is clear from any other old ink that maybe dried....that stuck the movement of the service station...
if it doesn't work again...folow the next step...
1. u have to pull out the service station... ( the difficult one ..!!! )
2. under the service station, there is a small motor....just find a new one and change it..
it works...
.....i found this new motor in an old hp printer's service station that i have...
thank u
Jul 04, 2008 | HP PhotoSmart 7760 InkJet Printer
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
351 people viewed this question
Seeker5211
Seeker5211
