Question about Dometic Refrigerators
Which way do you turn the temperature knob to get the damn thing colder, clockwise or counterclockwise?
yalmer
  • 552 Answers
SOURCE: Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Posted on Mar 17, 2008
Maytag317
  • 1136 Answers
SOURCE: THERMOSTAT
Hi, Here is the Part # 5304421256.
This is a common issue with this model. Just remove the 4 screws holding the control panel up and you will be able to see the thermostat/cold control
I hope this helps you.
Please let me know if I can assist you further.
Vicl
Posted on Jul 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore refrigerator model # 106.59512990 is not turn ON
The thermostat is bad and must be replaced.
Posted on Apr 27, 2010
caroldon
  • 17130 Answers
SOURCE: For the temperature, to make it colder to we turn
Normally the lower number is more cooling and hence the setting is ideal to be kept at mid point.
In twin door adjustment witth single control lower setting more cooling to freezer and as it goes up the temp of the fridge increases.
So you might need to recheck with this model
Posted on Sep 16, 2010
bobicehouse
  • 1524 Answers
SOURCE: Admiral Refrigerator Model # RTSA154A temperature
Clockwise colder. Order new knob Bi Coastal Appliance Parts 1-800-673-1262
Posted on Nov 01, 2010
Testimonial: "Thank You bobicehouse! I don't have a manual and could not find one online. thanks again! : )"
Where is the air and heat blend motor on a 2000 dodge dakota?
Hi Sharon, I'm glad to help. Your 2000 year doesn't have a motor for the temp door. It operated by a cable running from the control head to the temp door and you work it manually. If you can't control the temperature from hot to cold, sometimes the cable come off or breaks. Here how you can see the cable to see if its working. Remove the radio and right behind it you will see the cable attached to the door, while watching it move the temp lever from hot to cold and watch it. If it is moving then its most likely out of ajustment. If it is not moving, then you'll need a new cable. Just in case it is moving, I'm attaching the instruction on how to adjust it below. Hope this helps and have an awesome day Sharon!
TEMPERATURE CONTROL CABLE
Any time the heater-A/C control or the temperature control cable are removed and/or replaced, the following procedure must be performed.
  1. The temperature control cable housing and core must be installed at both the heater-A/C control and the heater-A/C housing ends, and the heater-A/C control must be installed in the instrument panel. See Heater-A/C Control and Temperature Control Cable in the Removal and Installation section of this group for the procedures.
  2. Rotate the temperature control knob on the heater-A/C control so that the knob pointer is in the 12 o'clock position.
  3. Pull the temperature control knob straight out from the heater-A/C control base until the perimeter of the knob (not the knob pointer) protrudes about 6 millimeters (0.25 inch) from the face of the control base.
  4. Rotate the temperature control knob to the 1 o'clock position. Push in on the knob slightly and continue rotating the knob to its full clockwise stop. The knob pointer should be aimed at a position about 8 millimeters (0.315 inch) beyond the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If the knob is not pointed to the correct position, go back to Step 2 and repeat the adjustment procedure.
  5. Rotate the temperature control knob counterclockwise until the knob pointer is in the 12 o'clock position again.
  6. Push the temperature control knob straight in towards the heater-A/C control base until the perimeter of the knob (not the knob pointer) is flush with the face of the heater-A/C control base.
  7. Rotate the knob to its full clockwise stop again. The knob pointer should be aimed at the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If OK, go to Step 8. If not OK, go back to Step 2.
  8. Rotate the knob to its full counterclockwise stop and release the knob. If the knob springs back from the counterclockwise stop, the self-adjuster clip that secures the temperature control cable to the blend-air door lever is improperly installed. See Temperature Control Cable in the Removal and Installation section of this group for the procedures. If the knob does not spring back, the temperature control cable adjustment is complete.
May 14, 2014 | Dodge Dakota Cars & Trucks
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
Is there a way to change the factory settings to make it colder?
KC2000, BRL2000BL, BRL2000SS: How to set temperature range to a cooler setting.
Unplug the unit from power
1. Unfasten screws indicated below.
2. Carefully pry the knob off.
3. Slide the dial out of the box.
4. Unfasten the screws with a Phillips screw driver.
5. The thermostat adjustment screw can be modified by, FIRST turning the screw clockwise until it is "finger snug" - DO NOT OVER-TIGHTEN.
THEN turn it counterclockwise 2 total turns.
6. Reassemble. Test for 24 hours. If the temperature is too cold, repeat steps 1-5 and in step 5 turn the screw counterclockwise three total turns instead of two.
Jan 08, 2011 | EdgeStar KC2000 Beverage Cooler Commercial
The ac won't work right
The first knob controls the temperature. Turning it counterclockwise will lower the temperature, clockwise will raise it. Pressing the button will turn on the circulate function (recirculates the air from the cabin).
The second knob controls the fan speed. Counterclockwise will reduce the fan speed, clockwise will increase it. Pressing the button activates the A/C compressor (allows colder temperatures).
The third knob controls the flow direction. Each picture indicates where the flow will go. Pressing the button activates the rear defoggers (in some models, it will also activate the heated side mirrors).
Jul 06, 2008 | 2008 Mitsubishi Lancer GTS CVT Sedan
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Magic Chef 61EA-3KX oven knob hard to turn
nothing magical here, sounds like the thermostats on its way out, not servicable part needs replacing.
Feb 26, 2008 | Kitchen Ranges
Refrigerators Logo
240 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
