HI NENITA, Did you try these codes--> 024, 040, 098
Setting Steps: Input Code
1.) Find out the 3-digit code for the TV that you need to control from the "Code list" In case there are several groups of codes available, please use the first group at first; in case that your TV brand has no matching code in the code list, please try the "Search For the Correct Code" mode described later.
2.) Press and hold the "Setting" button at first, then press the "Power" button. Release both buttons after the indicator light illuminates, indicating the status of code input; in case the indicator light is in other status, it indicates that it's yet to enter the code input status, and this step shall be repeated till the light illuminates.
3.) Input sequentially the 3-digit code that you have obtained. The indicator light flashes once when one digit is input. After the input of the code, the indicator light extinguishes; in case indicator light flashes twice successively, it indicates that your input is wrong and you need to input again.
Note: In case the indicator light keeps illuminating after two flashes, you only need to input the correct 3-digit code and do not repeat Step 2, otherwise Step shall be repeated for resetting.
4.) When the Indicator light extinguishes, the setting ends, then you can remotely control your TV with the remote controller.
SOURCE: RCA Universal Remote Control Code
sony code is 002
Programming a Device using Code Search:
SOURCE: Universal Remote Control cannot find code
I have the RCA RCU600D remote and i cannot get it to work with any codes listed for my Panasonic DVD-RV20 dvd player. Any ideas???
SOURCE: code number to use on universal remote control on a hyundai ditital tv model hy3438
just buy another universal remote which is having teach method... by using this remote u dnt need any codes... just once use the remote by which the appliance is working for teaching it then u can do any operation...
SOURCE: GE universal remote for Ilo brand tv
www.remotecodelist.com ...........................................T.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
