Question about IBM Office Equipment & Supplies
Broken keys? I have two letter keys that once depressed, stay down & one key that simply doesn't type the letter.
  • Dick O Reilly May 11, 2010
    Model would be very helpful. DickyO
  • IBM Master
  • 3,594 Answers
The key levers and pawls are probably gummed up take it to a shop for a clean and lube.
DickyO
Posted on Jul 31, 2009
The "f" key broke.when we press the key the type bar will not go up and make the letter
Take a paper clip and bend a 90 degree bend at the end. See if you can pull the f key back up, then depress the f key and see if the letter comes up. If you pull the key up, and push it back down, sometimes this will cure sluggish (gummy) keys.
It is possible that the spring under the key is broken, but look for staples, paper clips, etc under the key.
If you take 2 paper clips bent at 90 degrees at the tip, you should be able to CAREFULLY remove the f key top (one paper clip at each side wiggling it up side to side) and be able to see under the key.
Also, try this: Take contact cleaner (NOT WD40! It will kill electronic circuits!) and spray the key. If it is gummy, (sluggish) you should be able to restore free motion.
If the spring is broken, take apart a ball point pen, remove the spring, and put it around the shaft of the key, put the key back and, and hopefully it will push the key back up.
But try the spray contact cleaner first. You can get some from Radio Shack (or at least you used to be able to...)
Jul 02, 2014 | Brother GX-6750 Typewriter
Connect to a monitor
When you connect an external monitor to your laptop, you have to switch the video signal from the laptop screen to the external monitor by holding down the blue lettered <FN> key and depressing the blue lettered Function (FN) key that has ( CRT/LCD ).
Jun 24, 2013 | Dell Latitude E6400 Notebook
Want to make german Umlaut symbols on keyboard
Every so often you may find you need to type a character on your computer that is either foreign or just not available on a standard keyboard.
The German umlaut is once such symbol.
Used in the German language to indicate a change in sound, the umlaut can sometimes be found in names and words we use in the United States as well.
The literary Bronte sisters, for example, use an umlaut over the E in their last name.
Umlaut's can be found over the vowels A, E, I, O, U and Y in both lowercase and uppercase forms
Hold down the alt key on your PC.
The next step depends on the vowel and case you want for your umlaut.
If you want a lowercase A with an umlaut, type the numbers 0228 on the keypad while holding down the alt key.
If you want an uppercase A with an umlaut, hold down the alt key and type 0196.
Hold down the alt key and type 0235 for a lowercase E with an umlaut.
Hold down alt and type 0203 for an uppercase E with an umlaut.
Hold down the alt key and type 0239 for a lowercase I with an umlaut. Hold down alt and type 0207 for an uppercase I with an umlaut.
Hold down the alt key and type 0246 for a lowercase O with an umlaut.
Hold down alt and type 0214 for an uppercase O with an umlaut.
Hold down the alt key and type 0252 for a lowercase U with an umlaut.
Hold down alt and type 0220 for an uppercase U with an umlaut.
Hold down the alt key and type 0255 for a lowercase Y with an umlaut.
Hold down alt and type 0159 for an uppercase Y with an umlaut.
Typing an Umlaut on a Mac
Hold down the option key on a Mac computer and press the letter u.
Then release both keys and type the letter for which you want the umlaut.
For example, if you want a lowercase A with an umlaut, you would hold down option and u, release, and then type the letter a.
If you want an uppercase A, you would hold down option and the u key, release and then type the letter A.
Hold down option and u, release, and then type the letter e for an umlaut over a lowercase E.
If you want an uppercase E, you would hold down option and the u key, release and then type the letter E.
Hold down option and u, release, and then type the letter i for an umlaut over a lowercase I.
If you want an uppercase I, you would hold down option and the u key, release and then type the letter I.
Hold down option and u, release, and then type the letter o for an umlaut over a lowercase O.
If you want an uppercase O, you would hold down option and the u key, release and then type the letter O.
Hold down option and u, release, and then type the letter u for an umlaut over a lowercase U.
If you want an uppercase U, you would hold down option and the u key, release and then type the letter U. And for an umlaut over an uppercase Y, hold down option and u, release, and then type the letter Y.
For a lowercase Y, hold down option and u, release, and then type the letter y.
Apr 21, 2013 | Computers & Internet
My inspiron 1545 types two letters at once
On most laptops there is a function key that will lock the keyboard.
You would need to pres the [Fn] key and the appropriate [F#] key. In mine the combination
would be [Fn+F1] keys. If you shut down to re-activate the keyboard you will loose whatever you are working on.
hope this helps
Aug 15, 2012 | Dell Inspiron 15 1545 Notebook
I have a radio in a truck i bought and the battery died. the guy gave me a code and i cant get it to take in the radio any help would be appreciated
Kenwood car stereos are protected against theft by four digit security codes. If a thief steals a Kenwood car stereo, they will not be able to use the stereo until they enter the secret for digit security code.
Unfortunately, many legitimate owners are also locked out of their Kenwood car stereos due to these security codes. This typically happens to people who buy used cars from people who forget to share the security code. However, it also happens to people who simply forget their security codes after several years.
  • KCAR - This seems to be a "backdoor" to some Kenwood models.
  • 3051 - This is the security code which is printed in the manual of many Kenwood models.
  • 1234 - This is a security code commonly chosen by Kenwood owners.
  • f the car battery fails or is disconnected, the Kenwood will ask for the security code. The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
    Type 1
  • During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
  • Enter the security code using your Kenwood remote.
Type 2
  • Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
  • Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
  • 5
  • 5
  • Track Up
  • 2
  • 2
  • 2
  • Track Up
  • 2
  • Track Up
  • 7
  • 7
  • Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in Some Kenwoods There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Dec 02, 2010 | Kenwood KDC-MP332 CD Player
I forgotted the code how can I reset the stereo
Many Kenwood radios are configured with the same security codes:
* KCAR - This seems to be a "backdoor" to some Kenwood models.
* 3051 - This is the security code which is printed in the manual of many Kenwood models.
* 1234 - This is a security code commonly chosen by Kenwood owners.
Entering your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
Type 1
* During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
* Enter the security code using your Kenwood remote.
Type 2
* Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
* Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
* 5
* 5
* Track Up
* 2
* 2
* 2
* Track Up
* 2
* Track Up
* 7
* 7
* Track Up
Newer Kenwood models have the security information stored in non magnetic flash memory.
Once the code is set, it cannot be retrieved by a "backdoor method".
Proof of ownership is required. You can take the radio in to any AUTHORIZED Kenwood retailer - and in 10 minutes - they can have your radio reset for you.
If all else fails, you can send your stereo back to Kenwood to have the security code reset. They require proof of purchase.
This can be a receipt, or a used car invoice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2010 | Kenwood KDC-MP4028 CD Player
My typewriter carriage doesn't move along as I type.
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
KDC-716S sometimes plays CD, other times just tray drop
Common Kenwood Security Codes
Entering Your Kenwood Security Code
Type 1
Type 2
5
5
Track Up
Track Up
Track Up
7
7
Track Up
A Security Code Bug in some Kenwoods
Jun 01, 2009 | Kenwood KDC-716S CD Player
The num lock key controls letters on regular keyboard.
Let Number key stay off then you could use normal 1234567890 that is between QWERTYUIOP and F1-F12
May 22, 2009 | HP Pavilion DV9920US Laptop
Function needs to be pressed down to type letters
Make sure the num lock key is not depressed.
Dec 28, 2008 | Dell 0Y3740 Keyboard
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
